The Car (and jeep)
Re: The Car (and jeep)
seatbelts. did u miss my message frank ?
- lozz
Cheers mateFarmerPug wrote:Lozz i got the handbrake thingy out, the springs in good nick.
how much do you want for it?
have you got a pic of it please so ican check what spring looks like on it mine doesnt apear to have a spring
here you go:
as you can see its mounted to the rear ashtray back, you will need to take the centre console out to get at it which is no biggie. Then this thing will clip into place.
Its not very clean in the picture, but ill clean it up like new for you.
Whats £10 sound like, thats the postage and all included.
- lozz
Arr feck going off that pic iwill need a full handbrake lever there must be some plastic or something missing off it,FarmerPug wrote:here you go:
iwill see if ican sort a camera out and show you what imean,
When the handbrake is up theres a big Gap there must be another part ineed too,
thanks for your help mate
a big gap below it?
there is a bit of trim for below it yes
- lozz
its hard to explain properly,FarmerPug wrote:a big gap below it?
when the handbrake is up theres a big Gap inbetween the handbrake and that part in your picture,
im not sure if something as been snapped off the handbrake some sort of cover,
theres something not right,
if someone put there finger in it a rear passenger it wouid take top of there finger off ,
it dosent look right ,
ill get a picture out of my exec and then we can discuss this better.
- lozz
cheersFarmerPug wrote:ill get a picture out of my exec and then we can discuss this better.
ok its not the exec, even better the handbrake in the breaker car:
Ooowee! Was someone keeping pigs in there?
- lozz
cheers mateFarmerPug wrote:ok its not the exec, even better the handbrake in the breaker car:
its the middle bit thats got apeice missing going off your pic,
so it looks like iwill need a full lever unless that peice seperates but im not much sure it will do
iwill check mine tomoz and see if it does come apart
i dont know what your referring to here? can you draw an arrow to what it is your after?
- lozz
the red mark indicates the bit that is missing,
sorry about the crappy Arrow ive not long got in from walking the Ghounds and its fecking freezing
hands are frozen still..
ok ill try and get that bit off.
The Jeep mechanically is finished £30 it cost me to get the sump fixed and he has done an ingenious job at fixing the rocker cover bolts, a new threaded bar was welded on top, and the nuts sit above the cover.
Now its off to the auto electrician. And im pulling the 406 seats out and putting them in, should improve the comfort a bit.
