I have a 2001 406 2ltr HDI estate and my n/s dipped headlight isn't working.
I have changed the bulb (twice, thinking the first new bulb must have been dud) and I've checked the fuse (No 31 I think it was according t the handbook) which was not blown.
Is there anything else that might be causing this problem?
Any help would be much appreciated.
Thanks in advance.
Headlight inop
- Site Admin & Mad Biker!
Re: Headlight inop
Welcome in mate!
Possibly fault with the relay if the fuse is ok? Either that or wiring fault/stalk fault.
- Newbie
Re: Headlight inop
Can you tell me which relay please and where it is located
Also how do I check it?
Re: Headlight inop
I'd get the multimeter out and check things like the bulb socket and fuses, trying to see where there is electricity.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Re: Headlight inop
I couldn't tell you which relay as I've never owned a D9, however check this page for a link to the Haynes
To test just swap the relay with a different circuit!
Re: Headlight inop
If I'm reading this right the engine fuse panel on all D9s is the same, just on earlier cars the wiring is part of the fuse panel. It's a bit confusing on the parts diagrams as it only mentions from July 2001 but if this isn't just another cock-up you should look at fuse 9 there.
- Newbie
Re: Headlight inop
Thanks for the help, it's sorted now.
It was a fuse, I had already looked at them and they looked ok, but when I took them out and looked more closely I realised one was cracked.
Thanks Again
Thanks Again
Re: Headlight inop
Excellent, that's what we like to hear!
