Lower rear mount????
VespaSkin
Post by VespaSkin »
Back again.....
Just a quick check before I order - on driverside I have just noticed that a rubber mount, near driveshaft, bolts on to the lower rear of the block and has a rubber centre, has split - is this the rear mount? looks like this ( http://cgi.ebay.co.uk/PEUGEOT-206-1-4-1 ... 9129408753 ) but on a V reg 406 2.0 HDi
Any info greatly appreciated - if you have a Haynes for the 2.0HDi 1999 - 2002 it is on page 10.8, picture 10.3 and the bit I'm on about is the rubber where bolt A is highlighted
Gaz
Re: Lower rear mount????
jasper told me yesterday or the day before :? to change the bottom mount you have to remove drivers side drive shaft and take the whol mount off then get a garage to change the bush
that was for my 1,9 td .. it will probably be a similar procedure for the HDi ...
VespaSkin
Post by VespaSkin »
Ahhaa - it's the rubber that the movement limiyer bolt goes through
VespaSkin
Post by VespaSkin »
It looks like I could get to it with the car on ramps, new mount in freezer and heating up housing once I cut out the old one with my Dremmel - any views on this - also, is it the rear mount I need to order or steel elastomer or are these the same thing? Its where the bolt for the movement limiter goes through, it joins to the horizontal Y shaped jobby and under/near the driveshaft
Cheers troops
Gaz
member
adam486749939202048842 did his on the car and he said he would never do it again
its a real pain , hard job
but if you feel upto it good luck with it maste let me know how u get on as i want to do mine 8) 8)
