Help stuck in field and car won't start
gtanswell26
1.6 8v
Post by gtanswell26 »
Hi guys
well I'm stuck in a field and car has decided not to start it turns over fine but won't fire it's a 2.0 hdi d9 please any suggestions would be very handy
Re: Help stuck in field and car won't start
Immobiliser having a brain fart? Lift pump?
I'm not sure what to suggest apart from giving the lift pump a tap, have you got breakdown cover?
plod
Post by plod »
In the 4 years of ownership of my hdi, the only time it wouldn't start, the fuel supply trip switch had gone off - up near passenger wing under bonnet with red top to it.
Pressed it back down, and all was good
1999 D8.5 HDi GLX - Sold :(
Oh yeah the inertia switch! Especially if you're parked in a field!
gtanswell26
1.6 8v
Switch seems ok but fuel pump under back seat not making any noise
is there a relay or anything I can check?
It's usually the pump itself that siezes; tap the pump housing and try again, that has worked for some guys on here temporarily.
Hope you're not too long getting home anyhow!
gtanswell26
1.6 8v
Car on low loader will investigate when home
omega
Post by omega »
why hasnt anybody asked
what was the car doing in a field?
neildavies
Post by neildavies »
Some things are best left to the imagination...
2007 307cc Sport 2.0 HDi 136
Well i thought of asking but decided not to for fear of being called a pervert !!
Why would anyone call you a pervert?? :roll: :cheesy:
Because in the past i think i may have been mis-understood :roll:
* and i bet they were at it !!
