Hi there,
cant tell you if that one is compatible, one the techy types will be able to help you out there,
but as for it not recognising it from the head unit, thats because you will need to have the option switched on in the BSI, and sadly thats a stealer job or at the very least a specialist pug place or maybe if your lucky a member close by might have the right software and and be able to do it for a beer token or two
its not much of a job for somebody with the right equipment, but sadly not DIYáble unless you have the gear
HTH
P.S if you stick your location up in your profile it helps people who might be local to offer help if they can
And welcome on in mate
