Hi.
I've a 2001 2.0 HDI estate and I plugged in diag box earlier today and found a few faults that cleared nicely except these. Could someone please advise?
Instrument Panel
- Remote intermittent fault: Engine speed information. Incorrect value received.
- Remote intermittent fault: Coolant temp info. Incorrect value received.
- Remote intermittent fault: Vehicle speed info. Incorrect value received.
Help?
Sent from my iPhone using Tapatalk
Instrument Panel (global test) faults
Re: Instrument Panel (global test) faults
See these all the time on various cars, don't worry about them.
Unless you actually notice your panel misbehaving, or they become permanent faults, you can ignore them.
Thanks. Not noticed anything as yet. (Touch wood)
- rwb
They're intermittent: just clear them.
As jonsowman says, these are normal!
Thanks guys.
I saw the same on my car (just DiagBox working yesterday), and was surprised it reported faults on all these things but *not* the fuel gauge which I actually do have trouble with (sometimes sticks about half-way, which I hear may be bad solder joints?).
2002 2.0 HDi 90 Rapier saloon (for sale)
Other faults to ignore are;
Pre-ignition relay, which is normally just glow plugs which are not really needed in an Hdi
Most intermittent faults - some can be triggered by a blip when starting, low battery, speed bumps.....
If you tinker too much you may get in trouble....
