engine fan fuse
engine fan fuse
i'm getting my 110hdi remapped by "hdi-tuning" by using the file service, i've got the galletto 1260 software and leads and have read the ecu and saved a copy no problem at all but what i did notice is that when the software was reading the ecu the engine fans come on at full blast it didn't seem to cause a problem and i've heard it's normal for them to come on, i'm just a bit worried that when i'm uploading the remapped file it might cause a problem so i thought i would just pull the fuse to the fans but i can't find it, anyone know which fuse it is
Re: engine fan fuse
If it has one it's MF1. If it has one...
Might help - viewtopic.php?f=1&t=18699&p=192227&hili ... pg#p192227 pick a diagram 'cos I found you on the com2000 thread so I know your car is full-mux but I didn't find an RPO...
Re: engine fan fuse
Don't worry, my fans cut in every time it is plugged in to Galetto and it has been remapped several times ( thanks Eric ) - it seems a common thing on newer models...
Re: engine fan fuse
ok thanks guys i think i will just leave it alone and just let the fans run, i'm having a few issues with the lead so it looks like i will have to send it back for a replacement.
- Captain Jack
Re: engine fan fuse
My fans run as well when programming so don't worry about that
Re: engine fan fuse
great just need the leads sorting out for some reason the lead i've got won't read the ecu data but it will download the map from the car.
