engine fan fuse
davew
engine fan fuse
Post by davew »
i'm getting my 110hdi remapped by "hdi-tuning" by using the file service, i've got the galletto 1260 software and leads and have read the ecu and saved a copy no problem at all but what i did notice is that when the software was reading the ecu the engine fans come on at full blast it didn't seem to cause a problem and i've heard it's normal for them to come on, i'm just a bit worried that when i'm uploading the remapped file it might cause a problem so i thought i would just pull the fuse to the fans but i can't find it, anyone know which fuse it is :)
Re: engine fan fuse
If it has one it's MF1. If it has one...
Might help - viewtopic.php?f=1&t=18699&p=192227&hili ... pg#p192227 pick a diagram 'cos I found you on the com2000 thread so I know your car is full-mux but I didn't find an RPO...
Re: engine fan fuse
Don't worry, my fans cut in every time it is plugged in to Galetto and it has been remapped several times ( thanks Eric ) - it seems a common thing on newer models... :cheesy:
davew
Re: engine fan fuse
Post by davew »
ok thanks guys i think i will just leave it alone and just let the fans run, i'm having a few issues with the lead so it looks like i will have to send it back for a replacement.
Re: engine fan fuse
My fans run as well when programming so don't worry about that
davew
Re: engine fan fuse
Post by davew »
great just need the leads sorting out for some reason the lead i've got won't read the ecu data but it will download the map from the car.
