priming bulb
priming bulb
what would cause the primer bulb to go (semi) soft overnight? how does this cause poor starting? and how would I cure it? 2.1 td.
'97 2.1TD Estate
Re: priming bulb
air getting into the fuel pipes, check the bulb itself, the leak off pipes on the injectors (and the pip) and the fuel pipes.
Hmmmm, straight 6 goodness!
