Will it ever end now its revving high
Ok well most of the problems sorted apart from the squeak at starte up but now it has started to rev higher at 1000rpm instead of 900 rpm could this be the throttle position sensor playing up its done it once before few months back but when you turn the engine off and restart it then it disappears
Re: Will it ever end now its revving high
petrol or diesel?
Hmmmm, straight 6 goodness!
110 HDi
Thankfully this one's easy - you just need to wiggle the multi-plug connector to the throttle position sensor and it'll settle down.
