Anyone up for a challenge?
Re: Anyone up for a challenge?
I was wondering that, there's no point in spending ages describing engines as they're alrady done in great detail on the "real" Wiki. I just wanted to move straight along to the "how to fix it" stuff but I've no idea where to go for that.
Btw the trim levels are all on parkers.co.uk (e.g. http://www.parkers.co.uk/cars/equipment ... eriv=25329)
goes back to look and it's all changed - ah
I didn't do much at work todaysteve_earwig wrote:goes back to look and it's all changed - ah
Lovin' the Parkers link, i'll redo the table on the wiki when i get a chance, will get in much more info etc
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
- highlander
- PowerFlow Shill
Nutski - any chance of "borrowing" Wikipedia's "Stub" template? Oh, and their "Catdiffuse" template?
I'm getting the hang of the Category system; note the "Electronics" category, with the "In-Car Audio" subcategory, which has a "Head Units" article in it. More simple than I thought, which is good as it was worrying me a little. It's good, because you can put "[[Category:Engines]]" at the bottom of an article about head gaskets (or something) and MediaWiki will automatically sort it out so that if you click the "Engines" category, you'll be able to see that article, and all other articles about engines, sorted into alphabetical order
I'm hoping that we can all develop the list of categories on the front page so that they're useful, easy to navigate, and stuffed to the gills with useful info. If anyone wants to add extra stuff, please do (cos I know roughly sod all about cars
How do I add a "steering and suspension" catagory?
- highlander
- PowerFlow Shill
On the Main Page, click the "Edit" link at the top right.steve_earwig wrote:How do I add a "steering and suspension" catagory?
Scroll down the editor window until you see "*[[:Category:Wheels|Wheels]]"
Copy that line and paste it on the line above that (as "S" is alphabetically before "W"
Click "Preview" at the bottom to ensure your change went in OK, then when you're happy, click "Save", and that makes your change go live!
Ok, i'll give this one a whirlhighlander wrote:Nutski - any chance of "borrowing" Wikipedia's "Stub" template? Oh, and their "Catdiffuse" template?![]()
No worries i'll see if i can 'borrow' them, although i find when i 'borrow' something i have to 'borrow' about 10 more to get it working, will try and get it done sometime tonight.
On the same row as the Knowlegebase header you will see an edit button, click on this to take you into the code.....
We can stick it under Gearbox/transmission, so in the code look for the header or what you want to put it under:
Code: Select all
== Knowledge Base (incl. How-To's) ==
*[[:Category:Bodywork|Bodywork]]
**[[D8 Models]] (Pre-1999)
**[[D9 Models]] (November 1999 Onwards)
*[[:Category:Engines|Engines]]
**[[Petrol]]
**[[HDi]]
**[[Turbodiesel]]
*[[:Category:Gearbox/Transmission|Gearbox/Transmission]]
**[[Automatic]]
**[[Manual]]
*[[:Category:Interior Styling|Interior Styling]]
**[[Controls]] (Gear-Stick, Pedals, Steering Wheel)
**[[Gauges]]
**[[Seats]]
* Is top level
** Is 2nd level
*** Is 3rd level
etc....
Code: Select all
Using this format you would want:
Code: Select all
*[[:Category:Steering And Suspension|Steering And Suspension]]
Code: Select all
**[[Steering]]
**[[Suspension]]
Code: Select all
**[[Automatic]]
**[[Manual]]
**[[Steering]]
**[[Suspension]]*[[:Category:Interior Styling|Interior Styling]]
**[[Gauges]]
**[[Seats]]
I haven't tested this, just my understanding of Highlanders work
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
I knew i would get beaten to it for typing too much!
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
feels about 3/8 of an inch tall
I may be a bit late/out of touch/speaking out of turn, but my son showed me this today......http://www.ukcar.com/
- highlander
- PowerFlow Shill
Steve - give it a gosteve_earwig wrote:feels about 3/8 of an inch tall
I'm a computer tech, so I probably make it sound harder than it is. Really
If you still don't manage it, then why not post here what you want to post there, and I'll put it in for you?
I've added the category, all those lines of code looked scarey but it's a piece of cake (umm, is there a way you can protect all your hard work for thenext time I try anything?)
Not sure about sub-categories, steering, front sus, rear sus? I dunno
- highlander
- PowerFlow Shill
Steve,
Don't worry about it - I can fix any broken content, and anyway, WikiMedia automatically catalogues changes - so I can compare changes and revert any errant changes as needed
Well done; you've added that in just the right way. You can add sub-categories in much the same way as you did the main Steering/Suspension category.
Just below where you added "*[[:Category:Steering/Suspension|Steering/Suspension]]", add these lines:
When you save that, you'll see there are three new sub-categories of the Steering/Suspension page. When you go to create one of those category pages (by clicking on the red-coloured link), then you can put this line at the bottom of the page in order to group them into the main Steering/Suspension category (does this make sense?) :
[[Category:Steering/Suspension]]
Cheers
Graeme
Code: Select all
**[[:Category:Steering|Steering]]
**[[:Category:Front Suspension|Front Suspension]]
**[[:Category:Rear Suspension|Rear Suspension]]
Cheers
Graeme
So it links back to the main category - it's ok, I was looking at the pages you guys already did.
I'm an IT tech too, i can't learn by reading about things, I need to edit and break things to understand whats going onhighlander wrote:Steve - give it a gosteve_earwig wrote:feels about 3/8 of an inch tall
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
