99 1.9 SRDT cigarette light fuse position
SRDT
Post by SRDT »
Hello,
I'm looking to have the lighter socket only powered when the ignition is on. I've done some reading of forums but it's not totally clear. I tried location 23 as suggested in some threads but that affected the radio and probably more.
I've also tried socket 1 which seems to do the trick, I'm wondering has anything else been affected by moving the fuse into the top slot at position 1?
Find the image below for the layout before i moved the 10amp fuse up to the top slot at positon 1
hullcitytilidie
Re: 99 1.9 SRDT cigarette light fuse position
Post by hullcitytilidie »
Yes, move 10 amp fuse at No1 slot up a notch. Only lighter on that fuse. Regards Geoff.
http://www.peugeotlogic.com/fuses/fuses406/fuses1.htm
2003 2.0 HDi 110 S estate.
SRDT
Post by SRDT »
Thanks Geoff
