hello again all , im new to peugeot's , i have a 1.8 lx 1998 r reg saloon and when i put £10 of petrol in it barely comes out of the red , is there a warning other than the red/orange dot lighting up on the fuel gauge or does car just cut out ?.
i press the trip meter and get 45 mile to £10 then the needle has gone through red and cant read any lower but i dont want to let car cut out and suck crap off bottom of tank , the car runs superb and im just trying to gauge mpg 45 seems a bit low anyone else got a 1.8 lx know what i should be getting ? .
how many miles with red fuel warning light on ?
junction 7 m62 st helens wa9 4bd
- highlander
- PowerFlow Shill
Re: how many miles with red fuel warning light on ?
Your engine is probably the same as mine (I've got the 1.8l 1999 model).
The tank has between 65 and 70l capacity. On average, I get about 350 - 400 miles before the light comes on. Granted, I sit in traffic a lot every day to/from work though (more than an hour to travel the 7 miles back home from work, sometimes as much as 2 hours).
If I just do motorway miles, then I can usually get 550 miles to a full tank.
I have no trip computer in my LX-spec D9, so I can't really help you with regards to what the car thinks I should be getting.
Cheers
Graeme
Cheers
Graeme
maglite1 wrote:hello again all , im new to peugeot's , i have a 1.8 lx 1998 r reg saloon and when i put £10 of petrol in it barely comes out of the red , is there a warning other than the red/orange dot lighting up on the fuel gauge or does car just cut out ?.
45 miles to a tenner sounds good to me, especially with the price of petrol these days. If i put a tenner in mine i get 40 miles if im lucky, and with the light on about 25miles. Ive not wanted to take it any further than that. If i remember correctly, when the red light comes on you have a gallon and a half left in the tank.
406 TURBO
Lowered 80mm
13psi Boost
Bailey Dump Valve
Full Powerflow Stainless System
Induction Kit
good bye MR2's!
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
I have no constructive input to this thread,
but by god im glad ive got an hdi, if thats what a 1.8 petrol does to the gallon
sorry but after a couple of hours in the cold fighting my dead fuel pump and a hefty chunk gone from my wallet today, this is what i needed to remind me why i went diesel.
sorry just wanted to be happy about the old oil burner for once.
I gauge D8 fuel gauges by turning the ignition on when the car's parked on the flat. If the needle flinches ever so slightly, you've got less than a litre left in the pipes. That was on my cars though, and may not be the same on yours. The only other warning is that the fuel pump will make a racket when it's pumping air. You've got seconds left.
I typically fill a 406 with 75 litres, with the most I've fit in being just over 78 litres.
- Site Admin & Mad Biker!
Expensive business nowadays!mjb wrote:I typically fill a 406 with 75 litres, with the most I've fit in being just over 78 litres.
You know it's going to be a tricky day when the needle doesn't move when you start the engine!
2.1td exec estate.
