Torx bolts, front caliper
Can someone please tell me the size of the torx bolts on the front caliper? 1998 2.0 hdi. Thank you in advance, Andrew
- 1.6 8v
Re: Torx bolts, front caliper
On the v6's with the Brembos the bolts are Tx55 and are tightened to 120Nm (or 90lb.ft), with some threadlock for good measure.
I can't imagine them being different on the other models.
Thanks for that. My range goes to T50 and I knew it was bigger but not sure whether it was T55 or T60.
- Site Admin & Mad Biker!
And pigs to undo!!!!ger wrote:tightened to 120Nm (or 90lb.ft), with some threadlock for good measure.
- mjb
- Site Admin
Unlike which other screws/bolts on the car?teamster1975 wrote:And pigs to undo!!!!
Mine were as tight as anything but found that trying to do it up a little first then undo it helps
Yep, a little whack often does the trick!
Peugeot and torque bolts
T 55
Plus a good soaking with Wurth 'Rost-Off Ice' use it with work, good stuff
