Pob
Posts: 93 Joined: Mon Apr 13, 2009 8:22 pm
Post
by Pob » Sat May 23, 2009 3:11 pm
Hi all,
My cat has just decided to fall to bits and make an annoying rattling noise
Would a cat from a 2.0 turbo fit a 2.0 16v?
Thanks,
Dan
Pob
Post
by Pob » Mon May 25, 2009 7:20 pm
The cat's are different... the angle on the joint to the manifold differs between the two
Dan
Smelliot
Posts: 58 Joined: Fri Feb 29, 2008 9:14 am
Post
by Smelliot » Wed Jun 10, 2009 5:10 pm
Do you have a turbo or a 16v?
I ask because I've got a cat knocking around for the turbo which I could do with shifting, only done around 3000miles before I put a powerflow stainless system on it.
2.0L turbo D8 exec saloon
406sri
Posts: 91 Joined: Sun May 28, 2006 4:04 am
Post
by 406sri » Wed Jun 10, 2009 8:07 pm
Hi Dan
if you are interested, I have a complete brand new exhaust system avaliable for the 2 ltr 16v for £85 collection only
cheers
Simon
nimike
Posts: 88 Joined: Thu Oct 23, 2008 7:12 pm
Post
by nimike » Wed Jun 10, 2009 8:22 pm
406sri wrote: Hi Dan
cheers
Simon
d8/d9?
406sri
Post
by 406sri » Wed Jun 10, 2009 8:56 pm
Sorry d8
Pob
Post
by Pob » Wed Jun 10, 2009 10:11 pm
I tried to fit a turbo cat to a 16v, but the angle wasnt right to fit a 16v. The reason I was replacing the cat was because it was rattling alot... when I removed the cat there is a bit of metal that was rattling inside the neck of the cat (The bit that bolts to the manifold) I pulled it off and it's fine now
Thanks,
Dan
