Engine rattle
406Iain
Engine rattle
Post by 406Iain »
Rightio,Hello.
Ive had this noise on my 406's engine for ages now (over 2 years) and Im finally pissed off with it.Thing is,its never got worse.
EW7J4 I think is the correct code (1749cc anyway)
It sounds like a faint clatter whan you rev it (sometimes) and also sounds like a blowing sound when driving,although as above it doesnt always do it.
Its hard to describe and sods law it never does it at a garage.
Its coming from the back of the engine somewhere,a mate seems to think its an injector.I hope it isnt.
I tried getting it sorted awhile back when I discovered a split vacuum hose which I though would sort it but of course it didnt.
Anyone any faintest idea of what it could be or even things i could tighten/check/remove and clean/replace.
Id be very grateful as it makes me want to cry at the moment!
407 GT multimedia :D
HimBigChief
Re: Engine rattle
Post by HimBigChief »
Exhaust manifold gasket leaking slightly? Although, this would make the noise more or less all the time then.
Image Image
Re: Engine rattle
Similar thoughts - exhaust flexible coupling maybe?
406Iain
Re: Engine rattle
Post by 406Iain »
Thanks for the suggestions chaps.
What I might do is pop it to my local exhaust place.Ive got ramps but the front bumper is low and it wont go on them without a faff.
HimBigChief
Re: Engine rattle
Quite hard to diagnose the manifold gaskets unless they are blowing all the time, but if you start the car from cold and then put your hand down and round the manifold, you may well fell a little puff of air onto your hand. They are more likely to blow from cold and also you can get your hand close to the manifold before it gets too hot.
Image Image
406Iain
Re: Engine rattle
Post by 406Iain »
I might check in the morn before i go out.
Ive just taken it for an "Italian tune up" (read 6k in 3rd and 4th round my favourite bit of road) and it never made a whisper (well apart from the rather pleasingly throaty engine note)
soon as I hit town again and started accelerating away from some lights in 2nd bam there it is again.
Pob
Re: Engine rattle
Post by Pob »
Mine is making a noise similar to yours... I think. Only does it when accelerating... I think it's the flexible joint, as the engine moves during acceleration the joint moves causing to blow
Mine also had a clatter to... It was the auxuilary drive belt tensioner pulley, might be worth a look.
Dan
406Iain
Re: Engine rattle
Post by 406Iain »
Pob wrote:Mine is making a noise similar to yours... I think. Only does it when accelerating... I think it's the flexible joint, as the engine moves during acceleration the joint moves causing to blow
Dan
Cheers mate,thats worth a look.Its doing my tree in.Its a lovely car and when its making that noise I just get fed up of it.Of course no one else can hear it but me!
Winkz
Re: Engine rattle
Post by Winkz »
Hi mate,
I think I may have the same Rattle as yours coming from the Drivers side if you have any Info could you Drop me an Email.
Thanks ,
Jack
Winkz
Re: Engine rattle
Post by Winkz »
I have just read up on this mate and I found out this could be our Timing belts going mine need's doing so your might do aswell!
supafrisk
Horse Whipper
Re: Engine rattle
Post by supafrisk »
More likely to be the auxilliary belt pulley. Try squirting wd40 (without getting it on the belt) onto the pulley and see if it goes.
Winkz
Re: Engine rattle
Post by Winkz »
It could be your timing Belt mate
Jack (Winkz)
406Iain
Re: Engine rattle
Post by 406Iain »
Timing belt was done less than 10k ago.Its def from the back of the engine somewhere down in the dark depths where i cant see.
