406 diesel won't start in cold weather
my 406 diesel turbo(N reg) won't start in cold weather. new glow plugs changed last march 08. when i spray cold start, it starts and works all day. in summer it was ok. only since last week, as the weather turned cold, it won't start. relay is ok as there is voltage and it cuts off after about 76 to 7 seconds. same problem last winter as well. hence, the reason for changing the glow plugs. after new glow plugs changed, the weather suddenly changed to warm. hence, all summer no problem. now it is cold, it won't start. please help. what can be the reason. thanks.
