HDI lift pump removel
Avgasandy
Post by Avgasandy »
Hello all
Just recently noticed the lift pump in the fuel tank has started to growl rather than a high pitch noise the car has always had on start up.
Been out in car today and the engine just cut out, when i turned ignition back on no noise from tank. Kept trying after about 20 mins tried again this time got growling noise back and car started. This has happened severel times today.
I have removed the rear seat and plate over the pump to remove it but cannot get the plastic clamp off that secures the pump in the tank, has anyone got any suggestions as to removing this clamp so i can fit replacement pump. Any advice would be greatly appreciated.
Andy
Re: HDI lift pump removel
when you say clamp are you refering to the black plastic ring
that screws onto the tank to hold it in place ???
Avgasandy
Post by Avgasandy »
Yes i am
I have not got anything big enough to put round it to turn it and cannot get my hands in there properly to twist it its on very tight.
if you look at the ring it has got like plastic vanes all the way around it
think they are to help you unscrew it, what i did was get a very blunt
screwdriver and small hammer and tap at these vanes until it started
to move i then used a cheap pair of very wide jaw mole grips the sort
they use to undo oil filters, or you could try a oil filter chain .
Avgasandy
Post by Avgasandy »
Thanks i shall have a go at that replacement pump arrives on Tuesday
keep you posted on how it goes
Just 1 more thing the engine light is showing on the dash will i need to get the ecu reset or is the car intelligent enough to realize its been repaired?
dont know about that one Andy because mine never came on :|
Avgasandy
Post by Avgasandy »
Hi fit new pump and spilt a bit of the old claret along the way.
Car now runs again as it did.
Also car did realize it had been fixed and engine warning light went off.
Thanks for your hammer and screwdriver advise
Andy
well done Andy glad you sorted it, yes spilt some blood myself :(
