gti-6 advantages
gti-6 advantages
is there any advanages in fitting gti-6 inlet and exhaust manifolds cams etc and will they fit ok on my 1.8 16v
- jameslxdt
Re: gti-6 advantages
they do fit and make substantial difference, ive still got an exhaust manifold for sale if you want
whats the difference between mine and your one
has anyone done this mod on theirs if so was there much gain
Does anyone know if you could fit an entire GTi-6 head? and would there be any advantage to doing so?
there the same casting but the valves are a different size iirc.
1990 205 gti16, xu9j4 power! graphite grey, white speedlines, 306 brakes, ice, half leather.
going to enjoy smashing ctr's
2000 d9 406 executive v6 estate with an auto box, bit of a hot hatch slayer ;) currently munching 'hot' hatches.......
- jameslxdt
mucho larger valves, double valve springs and a ported combustion chamber, the cylinder head, manifolds and ingition system is the only difference between the XU10J4R and the XU10J4RS
So it might be worth using the whole gti-6 cylinder head on a 1.8/2.0? I suppose then to see the best gains the ecu would need remaping unless a gti6 ecu would work in the 406. Only theoretically speaking, I don't plan on doing it.
