My 1.8L (Ew7J4) petrol 406 had the key and ignition key barrel pinched. I live in Oceania where Peugeot dealers or experts are nonexistent, so my only options are what I can get online.
I found an eBay listing of an ÉCU+ Bsi + key and barrel off a Citroen C5 with the same engine. Will my Peugeot run if I simply connect this set? To help you a little, I’ve attached a picture of my ECU followed by the set on eBay and a closeup of that ECU.
Another option I can think of is to send my current ecu to be remapped to disable the immobiliser, then hot-wire the ignition. Will that work?
Thanks for your help.
HELP! Key and barrel stolen!
Re: HELP! Key and barrel stolen!
From what I understand, apart from matching the engine, you also need to match other features of the car, such as if there's any variable power steering, air conditioned or not, etc. But I don't know what consequences it would make if it does not have 100% exact equipment.
Also if I'm not mistaken there's a way to enable/disable features in PP2000 depending on what equipment is installed in the car, but I'm not sure if those could apply in this case.
2001 406 D9 2.0i 16V 135 - planning to use it for at least 6 more years
1998 306 N3 1.8i 8V 103 - has been asleep for 8 years now
Only the the key and ignition key barrels were pinched? You mean just the metal? In that case you might want to replace just those. The electronic coding does not depend on the shape of the metal parts.josuekaboha wrote: ↑Mon Dec 07, 2020 11:20 am My 1.8L (Ew7J4) petrol 406 had the key and ignition key barrel pinched.
Do you still have a spare key? That you could use to open the doors, in case the keyfob or car battery has run down? If not you might also have to replace all the door barrels...
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
