Auto to manual
Auto to manual
Anyone here done an auto to manual conversion on a late model 2.0HDi (2003). Just wanting to know if any wiring mods need to be done apart from the start inhibitor on the auto selector. And any other pitfalls that may not be obvious?
Serial 406hdi licker
Re: Auto to manual
I couldn't tell you all the differences, but a manual will have a switch on the clutch pedal so the ecu 'knows' when it's depressed. Suspect the ecu map will be different - manual cars calculate which gear they're from engine & road speed, I believe the torque limits will vary depending on the ratio. Final drive ratio likely to be different, may affect speedometer accuracy.... and probably a few more I haven't thought of.
Re: Auto to manual
I know the BSI and engine ecu will throw a wobbly if they don't see the a/t ecu. Apparently there's a way to switch it off once the engine's started. I don't think the engine is physically different, I'm told the V6's are though. Other than that, I've heard that moderns are so over-complicated it's easier & cheaper to buy another car...
Re: Auto to manual
I saw a Ford conversion on the Autoshite Forum once, it was said that in a car's production the fact of whether it's an Auto or Manual is pivotal to the whole process, it's pretty much the first thing fitted (pedal box, gear selectors etc) so doing it afterwards is a BIG job and possibly a 'dashboard out' affair.
Re: Auto to manual
Steve,steve_earwig wrote: ↑Tue May 07, 2019 2:18 pm I know the BSI and engine ecu will throw a wobbly if they don't see the a/t ecu. Apparently there's a way to switch it off once the engine's started. I don't think the engine is physically different, I'm told the V6's are though. Other than that, I've heard that moderns are so over-complicated it's easier & cheaper to buy another car...
I'm not 100% sure on this but our resident coupe breaker Ade Bingham has done a V6 auto to manual swap
& has sold the stuff for other people to do the conversion.
It's by no means straight forward & easy but is doable & the engines are the same.
ps: makes a nice change to post car related stuff to you
2006 BMW e61 535d m-sport
run's for cover
Re: Auto to manual
Pretty sure I read that on here, after I said they wouldn't be different
Cars, schmars. My interests seem to be heading in a different direction these days, the 406 was bad for my back so it had to go and what I'm driving now is about as interesting as a wet weekend in Margate. There's damn all available these days that I do find interesting, I've even taken to surveying car parks for anything I'd like to own and I'm coming up with a big fat zero.
Re: Auto to manual
The conversion does require the motor/gearbox be removed to replace the pedal cluster as the auto one does not have any brackets to fit the clutch pedal. Will look into the clutch pedal switch thingey as well as I hope to retain the cruise control.
I know that PP2000 has the setting for the auto box to be set to "missing". Hopefully this will sort out that issue of not seeing the auto ecu. As for the mapping in the ecu.. will try it once converted and see. I do have an ecu from a manual HDi 90 that supposedly was remapped to 110 spec (it did have an intercooler/uprated turbo fitted when I got it) so will use that if the existing ecu does not come to the party.
I also have a complete manual loom from that same car, but I wrecked it as it had multiple electrickey/wiring issues which I could not solve so suspect the loom is faulty somewhere as swapping the ecu/bsi/door switches etc with known good ones did not solve the issues of windows/mirrors/heater fan etc not working.
I have done many auto-manual conversions but not on peugeots. Flashing the ecu from auto-manual is "relatively" simple in those I have done, but, knowing peugeot and their weird way of cobbling things together, I am expecting things to go sideways...
If it does not work, it is off to china with it, but would be a pity as it has an immaculate body/leather interior etc. Just hate autos though and this one is toast (normal AL4 issues) and finding a good working AL4 box here is impossible.
Re: Auto to manual
I probably have a selection of 2003-ish 110 HDi manual maps it it's any help. PM me your e-mail address if interested.
It's questionable whether finding a 'good' AL4 box anywhere was ever possible.
