Hi guys,new to this site,I have recently brought a 406 3L V6 saloon,i want to change the cam belt,water pump etc, and I am
having trouble locating the correct parts to do the job,any help ,contacts,information and advice would be very much appreciated
Many Thanks in advance Paul
V6 cam belt replacment
Re: V6 cam belt replacment
Hi & welcome aboard,
v6 saloons and estates are vanishingly rare on this forum.
You may find more info on the dark side: http://406coupeclub.org/
(But stick around you'll find much good info hereabouts too).
- 1.6 8v
In my experience the area of trouble is the water pump. When I had my belt changed a few months ago the water pump in the Gates kit, despite what the distributor (of the kit) said, needed some machining in order to fit. The 406 Coupe site has a lot of information on the variants of water pump. At least my car won't need another belt and water pump for 8 years (which I believe is now the recommended interval).
How did you get on with your belt change, PAP406 ?
2000 V6 GTX Auto Saloon (ES9J4S) non-mux
