BMF2 Fusebox,where is it?
grasmere59
Post by grasmere59 »
I'm having trouble with my rad cooling fan (2003 110 exec),it's the electronic type single fan with the one grey relay by the battery box,it doubles up as the A/C condenser fan as well as the rad cooling fan,i've no power to the relay or the large black connection that goes to the fan itself,i can find no fuses relating to the fan but i've googled it and it says there are 2 x 40amp fuses that seem fan related in "BMF2" fuse box under the bonnet but i can't see another accessible fusebox under there except the main big one,any ideas or am i missing something. :?
http://www.peugeotlogic.com/fuses/fuses406/fuses1.htm
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: BMF2 Fusebox,where is it?
It should* be one of the maxi fuses in the side of BM34 (engine fuse panel). There're some diagrams here viewtopic.php?f=1&t=18699&p=192256&hili ... er#p192256 yours could be the last one.
Also
grasmere59
I found another fusebox tucked down beside the front of the engine compartment fusebox,3 x 40 amp maxi fuses and some relays,fuses all o.k.,i have no live feed on the single white wire (fed from a single black wire from the loom)to the grey single relay that controls the fan,i ran a temporary live to the relay and the fan cut in and run with the aircon on,i have checked every fuse in the car nd all is o.k. so lost now why i have no live to the relay. :? :? :?
