how to check engine immobilizer
ipubudu
Post by ipubudu »
Hi all,
please let me know how to check my engine immobilizer working properly. i have peug 406 2.0 16v executive.
thanks
frog
Re: how to check engine immobilizer
Post by frog »
What i can think of: unscrew and remove the bottom steering column jacket, then unplug the transponder aerial (the round thing that slides over the ignition barrel).
Then start your car. It should run for only a few seconds, then it will turn off with a key symbol indicator lit up in the dashboard.
Maybe some-one knows a simpler way?
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
frog
Post by frog »
Or maybe it is possible to cover the black part of your ignition key in aluminum foil to prevent its transponder chip from being read... :D
Current "fleet":
Previously owned:
That's pretty much it....
You can remove the chip from the key, or unplug the receiving ring around the ignition, or unplug the grey lead on the comms unit - any of these will stop the signal from the key to the BSI.
Do you think you may have a problem?
ipubudu
Post by ipubudu »
good evening,
Thank you for valued comments. I'm going to check it in weekend and back to the forum Sunday evening.
ipubudu
Post by ipubudu »
hello.
I removed the circuit inside the key and start the car, engine was not started and key mark was displayed on meter cluster. again i put the circuit in to the key housing and start. it works properly.
thank you.
