Vehicle information for APR
As requested :cheesy:
Vehicle family 406
AS/RP N° 07791 89 3 0058 ( your RPO or DAM code is 7791 - for future reference )
Warranty Start Date 24/07/1998
BER e2*93/81*0026*03
General information;
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 406
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL SELECTION PACK
ENGINE INJECTION XU7JP4
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR PAINT SHERWOOD GREEN
INTERIOR TRIM TYPE DUNE VELVET "BM"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) BE3 V
ENGINE (TYPE) XU/XUD
OTHER BADGE WITHOUT FULLER BADGE
BADGE ST
Vehicle characteristics;
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X18
Fuel supply-Engine
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
SPEED SENSOR SIGNAL SENSOR HALL EFFECT
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
FUEL TANK INSULATION FUEL TANK INTERIOR INSULATION
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
RHEOSTAT RHEOSTAT
FAN 2 FANS , 2 RATES , IMPROVED
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING SAGEM
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 79
WHEEL STYLE ALLOY WHEEL OPALE
CLUTCH CABLE CLUTCH
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
TYRE (SIZE, TYPE) 195X65X15 H TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE BE3
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 23
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE WITH COMPENSATOR SLAVE
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
POWER STEERING FLUID COOLING SYSTEM WITHOUT COOLING
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
Body fittings
HORNS HORNS-HARMONY
AERIAL LONG ROOF AERIAL
WIPER ARM FRONT BLADE WITHOUT DEFLECTOR
SIDE MOULDINGS (TYPE) PROTECTOR W/O CHROME RING
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS WIDTH = 50
WHEEL EMBELLISHER (STYLE) SMALL DIAMETER HUB CAP
SIDE REPEATER INDICATORS SIDE FLASH-UNIT ASSEMBLY
INDICATORS WITHOUT SIGNALING LIGHTS
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
WASHER JET WINDSHIELD WASHER JET W/O DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION WITHOUT FULLER FUNCTION
EXHAUST TAILPIPE TRIM W/O EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING
WINDSCREEN GLASS (TYPE) NO HEATING WINDSCREEN
WINDSCREEN WIPER INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BUMPERS WITHOUT EMBELLISHER
MUDFLAP WITHOUT MUDGUARD
LUGGAGE RACK MOUNTING WITH LUGGAGE CARRIER
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES DOOR MIRROR AND HANDLES BODY COLOUR
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
WINDOW (TYPE) LAMINATED QUALITY 2
Interior fittings
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
REAR SEAT ARMREST WITHOUT REAR ARMREST
INTERIOR ALARM ALARM FORGET LIGHTS
LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITH LUGGAGE COVER
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
AIR CONDITIONING MANUAL CONTROL CAR HEATER
SPEED GRADUATIONS GRADUATION KMS/H
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE LONG CONSOLE
DRIVING POSITION LEFT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
DASHBOARD EQUIPMENT DASHBOARD LARGE GLOVE BOX COVER, WOODEN TRIM
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM TRIM BOOT + RR TAILGAT FLAP
DOOR TRIM WITHOUT WOOD EFFECT DECOR WITHOUT LEATHER
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL
POLLEN FILTER WITH POLLEN FILTER
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
INT. UPHOLSTERY ELEMENTS NOT WEAVED ROOF TRIM
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
HANDBRAKE WARNING LAMP WITHOUT PARKING BREAK INDICATOR
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE W/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG NO PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVERS SIDE ELECTRIC WINDOW AUTO STOP
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT) WITHOUT REAR SHELF LOUDSPEAKER GRILLE
ON-BOARD COMPUTER NO COMPUTER
COURTESY LAMP FR+RE DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
RADIO RECEIVER PERFORMANCE 3 RDS RADIO
REFRIGERATION AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
RHEOSTAT RHEOSTAT
AIR CON./TEMPERATURE REGULATION WITHOUT REGULATION AIRCON/TEMP
STORAGE (OTHERS) FRONT SEAT STORAGE + 2 BOXES IN BOOT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
CARPET DILOURS CARPET F330
LIGHTING TIMER WITHOUT TIMER
INTERIOR PROTECTION WITHOUT INNER PROTECTION
SWITCH ELECTRONIC ANTI-THEFT KEY
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
ANTIPOLLUTION MALFUNCTION WARNING LAMP BAD FUNCTIONING ALARM
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL,4 BRANCH
Electrical
ALTERNATOR ALTERNATOR 90 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 300
STARTER MOTOR STARTER MOTOR CL 3
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITHOUT FIRST AID BOX
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 I/R PLIP KEY + 1 PRINC UNIQ KEY
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
