Rear disc brake backplates
elton38
Post by elton38 »
Hello everyone this is my first post,
I used to own a 51plate 3.0v6 coupe but now being a family man, own a 406 estate! Missing the power and braking capacity thou!!
Does anyone know where I can get a pair of rear disc brake backplates from? Cheapest so far is Peugeot at £90 odd ponds each.
I have been trying to buy used ones but have had no luck so far!!
Cheers
Steve (elton38)
dirtydirtydiesel
Re: Rear disc brake backplates
Post by dirtydirtydiesel »
But bet is ade the coupe breaker but I seem to think he's out of them at the moment :(
Hi Steve - I'm afraid these are the proverbial 'Hen's teeth' so you may need to repair/rebuild the plates you have.
If your handbrake pins keep pulling through - a nut and countersunk bolt will do the trick, if the plates are starting to split - filler and good preserver paint ( zinc etc ) will have to do until a good set come up..... :(
These are the correct ones for rear disc/drum combo; the part numbers are 4211 81, and 4212 81
http://www.ebay.co.uk/itm/Peugeot-406-C ... SwgQ9VgUt7
Theses are for rear drums only;
http://www.ebay.co.uk/itm/Genuine-Peuge ... Swd0BV0eCU
Keep looking - you are not the first to enquire, nor will you be the last... :wink:
elton38
Post by elton38 »
dirtydirtydiesel wrote:But bet is ade the coupe breaker but I seem to think he's out of them at the moment :(
Thanks for the reply; i'll keep looking and maybe try Ade in a bit.
cheers
Steve
elton38
Post by elton38 »
GingerMagic wrote:Hi Steve - I'm afraid these are the proverbial 'Hen's teeth' so you may need to repair/rebuild the plates you have.
Thanks V much that's helped me lots. i think i'll try the repairs this weekend :D (if i can get the time!) The part no's are a good help too as i was having trouble finding them.
cheers
Steve :)
