5 beeps each time I turn the key on/off/ignition
nagydani
Post by nagydani »
For about a day, I can hear 5 beeps each time I turn the key to any position i.e. ignition, stopping the engine or even just turning on the electronics. There is no message on the display or even a blinking symbol on behind the steering wheel. Do you have any idea what this can be?
Re: 5 beeps each time I turn the key on/off/ignition
Hi.
If there is no warning..on the mfd..
Id try a b.s.i reset..
If I rember correctly..a 406 shouid only beep if..the handbrake is left on..lights left
On ..with key in ignition etc..
Or keys left in ignition with door-open.
Someone else might know more..its a long while since I've owned one..
nagydani
Post by nagydani »
It turned out that it had something to do with the seat/mirror memory. I remembered that after setting the memory there was a glitch in the process and started to move the mirrors twice. This morning I did a reset with a seat/mirror memory, and now the beeping is gone.
Thanks for the previous answer!!
I thought the seat ecu was too stupid to do anything like that :shock: Well done for finding it, I did a forum search for the beeps and came up with someone with the same problem a few years back, looks like they never sussed it, or at least didn't let us know what it was.
