2.1td hydraulic clutch
Uberderv
Post by Uberderv »
Hi,
I'm mainly after the master cylinder if anyone has one?
Cheers :)
Rolebama
Re: 2.1td hydraulic clutch
Post by Rolebama »
Aren't all the 2.1 TDs an all-in-one fitting? I have seen a couple of posts on here regarding this, and mine is definitely an all-in-one.
1998 2.1 GLX TD
I'd have thought you saw that most recently here - viewtopic.php?f=1&t=22461&p=226466#p226431
Does this thread mean that the HDi m/cylinder is totally different?
Rolebama
Post by Rolebama »
As far as I can tell the all-in-one was only fitted to 2.1s, and fitted to all of them. I won't be upset if proven wrong though.
(Maybe something to do with bellhousing casting for cable gears?)
1998 2.1 GLX TD
Uberderv
Post by Uberderv »
Steve - I'm still investigating possible replacements from other model Pug/Cit. The slave cylinder looks like it can be replaced from another model but the master is not looking promising.
Rolebama - Yup you are correct about them being fitted to all 2.1td 406's. I think it will be possible to repair it if it's a split pipe, in fact I know it works, I would like to incorporate a bleed point in the line between master and slave.
I managed to damage the master so would like to replace that without paying silly money :D
