fattail95
Posts: 409 Joined: Wed Jun 24, 2009 6:35 pm
Post
by fattail95 » Sat May 24, 2014 5:54 pm
Hi guys!
Got my PP2000 the other day, and noticed a permenant fault with the post/pre heating relay circuit, as below:
Is the issue with the small box next to the ECU?
Many thanks
Benjamin
150hp/330nm • Powerflow stainless exhaust • Kevlar clutch • Cat delete • EGR & Doser delete • Leather interior • Windows tinted • Cruise control • 5 dial cluster • Yatour bluetooth • Starfish alloys • Twin rear fogs
Posts: 19813 Joined: Thu Oct 04, 2007 6:09 pm
Post
by steve_earwig » Sat May 24, 2014 6:09 pm
They all do that sir, I think every single HDi that's been up on test reports the same issue. Clear it & ignore it.
Sent from my large intestine using a spoon.
fattail95
Post
by fattail95 » Sat May 24, 2014 6:11 pm
steve_earwig wrote: They all do that sir, I think every single HDi that's been up on test reports the same issue. Clear it & ignore it.
Does this mean that the glow plugs dont function at all then? Or just at reduced efficiency?
Many thanks
Post
by steve_earwig » Sat May 24, 2014 6:20 pm
Do you actually have a problem or is this something you've come across while you've been exploring?
fattail95
Post
by fattail95 » Sat May 24, 2014 6:42 pm
steve_earwig wrote: Do you actually have a problem or is this something you've come across while you've been exploring?
Just something I've come across whilst exploring
Posts: 3580 Joined: Fri Apr 06, 2012 9:02 pm
Post
by GingerMagic » Sat May 24, 2014 6:46 pm
Glow plugs are not needed in an Hdi unless you live somewhere at -15'c.....
I believe the later Hdis use the glowplugs to aid the regen if you have a DPF/FAP, but not really needed on an old 406....
I've not used glowplugs for 4 years.
Sent from my spleen using a whisk, live bait and a cornflakes packet
rwb
Posts: 2612 Joined: Thu Jun 17, 2010 7:53 pm
Post
by rwb » Sat May 24, 2014 7:41 pm
As above: clear it and see if it comes back.
If it does come back then it'll be either a relay or more likely the glow plugs.
And if it's working then you may choose not to fix it
If you had a 2.2 HDi with a functioning (haha) dpf then this can develop into regen failures.
OllieNZ
Posts: 489 Joined: Sun Mar 04, 2012 7:47 pm
Post
by OllieNZ » Sat May 24, 2014 8:50 pm
GingerMagic wrote: Glow plugs are not needed in an Hdi unless you live somewhere at -15'c.....
I can confirm that the later hdis use them for regeneration and dead plugs equal an antipollution fault [emoji20]
