Hi All,
I need new plugs for my 1.6 307 and was wondering what brand the oem ones are?
Glow Plugs
Re: Glow Plugs
Not sure on OEM but you can't go far wrong with Beru
Re: Glow Plugs
I was looking at either bosch or denso. Although after discussing it with one of guys at work he burned through a set of bosch ones fairly quickly and replaced them with denso ones that cost half as much and never went wrong.
Re: Glow Plugs
Bosch, NGK, or do it again within a few months......
Re: Glow Plugs
Are the NGK any good? @£7 a plug seems to good to be trueDoggy wrote:Bosch, NGK, or do it again within a few months......
Re: Glow Plugs
Yes! I wouldn't use anything elseOllieNZ wrote:Are the NGK any good? @£7 a plug seems to good to be trueDoggy wrote:Bosch, NGK, or do it again within a few months......
Re: Glow Plugs
Cheers Jasper,jasper5 wrote:Yes! I wouldn't use anything elseOllieNZ wrote:Are the NGK any good? @£7 a plug seems to good to be trueDoggy wrote:Bosch, NGK, or do it again within a few months......
Easy choice then, any tips for getting the old ones out in one piece?
Re: Glow Plugs
soak the threads in WD40 overnight and for a couple of days before you do the job.
