steam cleaning
tonko007
steam cleaning
Post by tonko007 »
Hi all i have been invited to a car show next month and as the engine is looking a bit grubby is it possible to steam clean a 406 2.2 hdi and what precautions should i take if any thanks again paul
Re: steam cleaning
hi, ..spray some wd40 in places first, mainly the electrical connection's.
You shouid be ok with steam, certainly better than jetwashing thats for sure,
FWIW -id sooner clean an engine bay by hand, old rag method ..Wd40 is brilliant at breaking down old oil and ming,
here is a pic of an old fiat icleaned up using old rags/toothbrush/wd40 and cheapo furniture polish,
Re: steam cleaning
On my 2.2Hdi, I simply use an old spray can of tyre-foam first to break down most of the grime, then wipe it off.
Then use an old tin of flash-dash or similar, spray it over and leave it on, wipe any excess drops off and it brings everything up lovely.
Most of my engine bay covers ( fuse box, ECU etc ) have broken clips so they fly of when jet-washed, which isn't great... :roll:
I'll post a picture later of my engine bay which looks quite tidy for a 192K motor.
+1 for Lozz - WD40 is a good cleaner too.
