OOOOH BUGGER!
OOOOH BUGGER!
we'll I've had my 406 all of 3 days and some little scrote has already tried to break in
luckily my neighbour spotted them and scared them off but my drivers door lock is now knackered
when I use the lock the barrel does nothing apart from keep spinning round so I now have to use the passenger side
any ideas folks before I start dismantling things?
Re: OOOOH BUGGER!
lock the door from the inside,
and keep turning the lock with the key until it opens,
try the oposite way too,
the 406 locks are fitted with a Anti-Razzle feature,so theives carnt break in.. the lock just turning after an atempt break in is normal,
its worth a try before fitting another lock,
Re: OOOOH BUGGER!
LOzz is right, try to use the key both ways up, turning left and right etc, and things in the lock may just correct themselves and then work.
A bit of WD40 may help as a one off.
Re: OOOOH BUGGER!
tried this but just keeps spinning
is there a diagram anywhere of the door mechanism in case anything has broken or come lose behind the doorcard or is it just a case of fit a new barrel?
Re: OOOOH BUGGER!
well this is now fixed
don't know how but i forgot to use passenger side this morning and went straight to drivers side...and it worked.
i'm keeping my eye on it though just in case
Re: OOOOH BUGGER!
Maybe the WD or whatever you tried to free it up with has worked it's way inside.
Also, not sure if anyone mentioned it but the lock will spin even with the right key of the lock is upside-down.
Re: OOOOH BUGGER!
might be worth me looking into that too. no-one has mentioned that beforesteve_earwig wrote:Maybe the WD or whatever you tried to free it up with has worked it's way inside.
how do I tell which way up is correct ? I'm presuming it's marked somehow
Re: OOOOH BUGGER!
Not that I could see on mine, I just thought it would be a good way of getting confused about the key working or not. Anyway, it's academic of the lock is working now.
Re: OOOOH BUGGER!
i spoke too soon as it's just spinning again so time to strip the door down and see what's wrongsteve_earwig wrote:Not that I could see on mine, I just thought it would be a good way of getting confused about the key working or not. Anyway, it's academic of the lock is working now.
Re: OOOOH BUGGER!
Ooh bugger indeed
Re: OOOOH BUGGER!
wd40 is not much good on locks, it just drys out,
perhaps a 3 in 1 oil in a spray form with a straw jobbie, (tesco's etc) might be worth atry,
idont bother much with wd40 anymore it seems to be a waste of money, its good at drying out moisure mind but as a lube its a fail,
Re: OOOOH BUGGER!
I can't work it out to be honest as it seems to have a mind of its own and work as and when it feels like it
I've stripped it down and can't see anything out of the ordinary so I'm presuming it's wear and tear on the barrel
