key remote battery low?
deanthedude1977
Post by deanthedude1977 »
Hi all
This morn after starting got the dreaded warning bong then on the mfd I saw key remote battery low--does this mean as it says??I only replaced it few months back--after dropping keys in sea?
Anyone else had this or know what it is?
Central locking all works on key fob etc?
Deano
Re: key remote battery low?
Did you use a budget price battery made by wing wong ?
if so replace with something decent. varta etc
other then that your fob might be faulty ive seen a few fobs drain battery's.
deanthedude1977
I, ll change battery if it does it again...thanks lozz
Mine did that 2 or 3 years back, just the once, no other signs, it's not done it again and It's still on the same battery that it came with when I got a new remote from Pug in 2007 (yeah, I know better now doughnigh :roll: )
Puggy2
Post by Puggy2 »
Have had my 406 for 3 years and both remotes work brill, have not changed either battery. On the same subject how does holding you key next head double the range? :cheesy: :cheesy:
