Wanted 15" Quartz Wheel trim x 1 (8 hole)
Chevetter
Post by Chevetter »
I am fitting some winter wheels and tyres to my 406 and am looking for 16 x wheel bolts for steelies (which according to the bloke at Peugeot are made of a different material to alloy wheel bolts as well as being taper-head) and some 15" wheel trims.
I would ideally like the Quartz wheel trims but will consider anything kerbing-free.
Please PM me, can pay by Paypal if posting or collect from Cambridge area, Wellingborough area or anywhere inbetween.
gumby6371
Re: Wanted bolts for steel wheels and 15" wheel trims
Post by gumby6371 »
If you've got a spare 20 minutes nip along to your local breakers, they're usually scattered around on the floor and they're a pretty standard fit.
Wear trousers with big pockets :cheesy:
16 of the things would be pretty heavy as far as postage is concerned.
I probably shouldn't say this but, in the spirit of don't try this at home, I found the tapers on my allow wheel bolts fitted the steels fine
Hi mate, you only need steel bolts with steel wheels, and alloy bolts with alloy wheels as the steel bolts cut into the alloy wheel, and alloy bolts don't bite well on steelies and could shake lose.... iirc
Chevetter
Post by Chevetter »
GingerMagic wrote:Hi mate, you only need steel bolts with steel wheels, and alloy bolts with alloy wheels as the steel bolts cut into the alloy wheel, and alloy bolts don't bite well on steelies and could shake lose.... iirc
Yeah, I wasn't going to risk using the alloy ones as the Mrs drives the car a lot too.
No takers then? I know postage will be reasonably expensive but Pug want ££££ per bolt and I don't have time currently to get to the breakers. I was thinking more like a tenner for a set of used bolts +P&P would be a reasonable price.
Chevetter
Post by Chevetter »
Thanks to the scrappie + fleabay I have now got a full set of used bolts plus 3 wheel trims.
Does anybody have one x 8 hole quartz wheel trim in reasonable nick that they'd be prepared to part with?
Re: Wanted 15" Quartz Wheel trim x 1 (8 hole)
I got a free set of BMW hubcaps from a mate, I just bought some Peugeot wheel centre stickers and put them over the BMW logo and put the hubcaps on my Mums 806 - it looked quite smart..!!
If you put a picture up of what you need I will have a look around.. :supafrisk:
