Tried removing the top on my fuel filter housing [110 hdi],couldn't budge it at all,any tips on getting it off so i can change my fuel filter? Theres nowhere to put a spanner on it to aid removal so i presume you should be able to twist it off?
Ta Paul
Fuel Filter Top Removal??
2002 110 LX ESTATE
1989 SUZUKI GSXR 711
Re: Fuel Filter Top Removal??
Take the housing off completely and put it gently in a vice ...don't tighten jaws....get a large set of water pump pliers and twist it off using those.....unscrew it .
Otherwise use an oil filter chain or belt wrench.
Watch the pipes....
Watch the pipes....
Hold on, is this a Bosch or a Mahle?
Sounds like the Mahle if there isn't a nut on top ....the Bosch has a nut.
Fairy nuff
I used a filter strap wrench to get mine apart.
steve_earwig wrote:Fairy nuffI used a filter strap wrench to get mine apart.
Strap wrench is what I meant to say
Cheers guys i'll give it a go
Paul
Paul
2002 110 LX ESTATE
