Immobiliser Fuse (10A) keeps blowing !
zola1
Post by zola1 »
Hi,
Firstly great forum thanks.
Car Details :-
406 2.2 Hdi Engine 2001 MYR Executive
Has anyone had a similar fault occur and managed to cure it ?...any help would be much appreciated..
Fault :- Fuse in Underbonnet Fuse box 10A blows whilst driving (engine stops !!!!, go to restart non start and Immobiliser lamp stays illuminated).
Replace fuse car started ran ok for a short time from next cold start....reversed out of drive ...same fault occured !
Will photo fuse box later to give exact location of the fuse and post asap
regards
Derrick
Re: Immobiliser Fuse (10A) keeps blowing !
Hi,
My guess wouid be the connector in the footwell wiring,
have you noticed any dampness in the carpet?
Might not be that tho,
see here :arrow: clicky viewtopic.php?f=3&t=16609&p=163335&hili ... ng#p163335
Was 2001 a bumper year for 406 sales? :( I'd ask the semi- or full-mux question again but I'll get a better idea once we see some pics.
If the pics don't clearly identify, post the fuse number too.......
steve_earwig wrote:I'd ask the semi- or full-mux question again...
Methinks we needs a sticky
zola1
Post by zola1 »
hi,
thanks for the replies...its Fuse no 24 in the underbonnet fuse box..Please see pic, i have ordered a CD from ebay to get the pinout of which circuits that fuse protects, any thoughts on that (be the weekend before i get the disc !
i will check the connectors in the footwell...looks like they are located on area at the base of the drivers A-post ?
Update on car drove to work this morning fuse did not blow no fault occurred ...intermittent short on circuit ! ..
cheers guys
zola1
Post by zola1 »
found the fuse function, please see pic...now all i need is to find the splice that separates the different feed wires ...the +12v's to isolate them individually ? i have not lifted the fuse box to see if its several different individual wires crimped to the output terminal of fuse 24 or does anyone have a wiring diag ?..longshot i know ?
cheers
That looks kind of semi-mux to me. I suspect the under carpet connector thing is a full-mux "feature" but I could be wrong.
I did have a wiring diagram, up until a few days ago when my pc had a nervous breakdown. Looks like I'll have to get installing...
zola1
Post by zola1 »
hi steve,
thanks for the heads up...if you manage to get the wiring diagram or further info drop it to us ...got this from autodata.
...not sure how accurate it is...trying to locate the splice is where i want to isolate the individual curcuits...any thoughts ?
thanks
derrick
I just stuck Sedre on this machine (takes hours) but I've already realised it doesn't show splices for semi-mux cars :( I can post a wiring diagram but I suspect that it's not going to get you any further. I also doubt the splices for a full-mux car would be any help.
According to this diagram, coming off of fuse 24 are...
1320 : engine management control unit
1620 : vehicle speed sensor /
1150 : pre-heat control unit /
1310 : air flowmeter
Perhaps you could try pulling the connectors for all these and seeing what is on the fuse with a multimeter.
zola1
Post by zola1 »
Err...what's Sedre ?...and Semi mux ?......
yes will go through the obvious wiring chafting etc then try and get the fuse to blow again !!!its one of them intermmittent faults, worse kind eh.
I have made up an extension to the fuse postion, got a 10A circuit breaker mounted by the steering wheel, if it blows whilst im driving down the motorway...no pwr steering etc etc !!i can reset instantly (if the short is just a spike !)
thanks for the heads up...whatcircuit detial do you have ?
cheers
derrick
SEDRE - Peugeot's own wiring diagrams which cover D9 (facelifted from June 1999) 406s (amongst others). All D9s are multiplex but early cars (up until July 2001) don't have as much of it as later cars, so we decided to call the earlier cars semi-mux and later cars full-mux to be able to differentiate without going into too much detail. I'm pretty sure yours is a semi-mux as the fuse panel looks nothing like my full-mux 406.
The wiring diagrams I have for semi-mux cars look like microfisches, I suspect that this is because that's how they started life.
Intermittent faults have driven me bonkers in the past so I have a pretty good idea what you're going through :(
