Laptop advice needed
I am thinking of getting pp2000 and was wondering what laptop i would need,i no next to nothing about pc's etc.I have been offered an E Systems 3086 laptop for £40,it's had a new hard drive (what ever that is) and reading off the spec label it has 1.6 GHZ,512 MB,40GB DVD+/-RW and Windows XP,all that means jack s##t to me so my question is would pp2000 work with this laptop?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Laptop advice needed
I know nothing about pp2000 but going by the laptop spec and what lexia says it needs you'll be fine.
This spec is for the product in the link below.
Software requires at least Intel Celeron/Pentium III 400 MHz, 128 MB RAM, 50MB free HDD space and USB 1.1 port (USB 2.0 recommended) and Microsoft Windows 98 SR2/2000/XP with the latest service pack installed.
If customer requires, we can prepare ready to work PC.
http://www.cardiag.co.uk/pp2000-lexia-3 ... ol-41.html
Looks OK to me too.
- sirwiggum
Handy that it's USB, some of the older ODB systems I've seen were serial port, you had to get an older machine - something like a Toughbook was ideal for the job.
That laptop should be up to the job no problem.
One thing to consider is the battery - on a lot of 2nd hand laptops the battery is more of a weight than of any use. If you can get a plug in your garage / extension lead you're sorted, but if your car is parked up in a block of flats car park and you need to run the laptop off battery, it is worth getting a new battery for it.
I've got it at home on loan at the moment and i turned it on and left it alone and the battery stayed up for about an hour and a half,it did keep going to sleep every 10-15 mins but i just kept waking it up and the battery stayed up,i wasn't doing anything with it so don't know if it is a true test of the battery life though.
- sirwiggum
Sounds fair enough, if it was sitting there with the screen lit up and not in standby/sleep, then sounds like the battery is in reasonable condition. Hour and a half is actually quite good for a 2nd hand machine!grasmere59 wrote:I've got it at home on loan at the moment and i turned it on and left it alone and the battery stayed up for about an hour and a half,it did keep going to sleep every 10-15 mins but i just kept waking it up and the battery stayed up,i wasn't doing anything with it so don't know if it is a true test of the battery life though.
That should be more than enough battery life for your needs shouldn't it?grasmere59 wrote:I've got it at home on loan at the moment and i turned it on and left it alone and the battery stayed up for about an hour and a half,it did keep going to sleep every 10-15 mins but i just kept waking it up and the battery stayed up,i wasn't doing anything with it so don't know if it is a true test of the battery life though.
My battery has been crap on here for a few years i'd have to run an extension if i was to hook it up to the car
