Hi All, I have developed a knocking when turning the steering wheel. On investigation I find the knock is coming from the front nearside suspension strut., looking from the top where the upper mounting bolts are ( with bonnet open ) I can see that when I turn the steering wheel it is trying to turn the strut and it clicks back and I get a click click, click ( or Knock ).
Anyone had this problem? Is it serious? Is the strut Knackered??
Any help would be really useful.
Thanks Guys in anticipation
Peogeot 406 Hdi
2001saloon
Knocking on Steering
Re: Knocking on Steering
Ihad that on a pug 306,
aclunk when you turned the steering wheel,
it was a Weak spring, ijust went to breakers yard and got a complete strut with spring, swapped it over, saves time and a few quid,
jonti007 wrote:Hi All, I have developed a knocking when turning the steering wheel. On investigation I find the knock is coming from the front nearside suspension strut., looking from the top where the upper mounting bolts are ( with bonnet open ) I can see that when I turn the steering wheel it is trying to turn the strut and it clicks back and I get a click click, click ( or Knock ).
Peogeot 406 Hdi
2001saloon
Sounds like the top bearing/mounting.
