406 hdi 110 rough idle
can anyone give some advise my 406 hdi 110 has rough idle. sometimes its ok but most of the time it runs rough ,when i rev it up its a bit lumpy till it hits the turbo then its ok ,there has been no engine management light come on to check it ,ive done a flow test to the injectors that was ok .changed the fuel pressure sensor still no difference ,changed diesel filter any one got any ideas
Re: 406 hdi 110 rough idle
Worth checking the engine mounts. You could guess at a possible faulty sensor, but it's probably best to get it diagnosed with a PP2000 sysytem - unlikely to get anywhere with general purpose code readers, as you don't have an EML light / permanent fault logged.
Suggest you add your location - someone nearby may be able to help.
