406 hdi wont start
406 hdi wont start
Hi All, hope you can help me!
Alternator drive belt disintergrated, and 1/2 a mile further on the engine died, and will not restart, cranks over but wont fire! Checked everything suggested on various forums and eventually forked out 50 quid for a bloke to come and do a diagnostic test. Came up with 3040 [or could have been 0340], cam/crank not syncronised, so today I have checked the timing, and its only a fraction out of getting both 8mm pins in at the same time. On this forum I have seen similar diagnostic results and its just been the crank sensor, so I dont feel my 50 quid was well spent.
Any ideas would be very much appreciated, cant help thinking the "flailling" belt damaged something, and its non starting is somehow related.
Happy new year to everyone
Phil
Phil
Re: 406 hdi wont start
Had your timing belt been changed at any point?
Peugeot 406 2.2Hdi Coupe '02' Plate
Metallic Black(silver & black edition)
Manual, Rear Tints.
Manual, Rear Tints.
the 8mm bolts being a fraction it is probably your answer.
- lozz
Hi. Can you hear the lift pump in the tank /priming,/running when you put ign on, ?
Thanks so far!
Timing belt etc was changed back in february when the vibration damper pulley went at 70 on the A14, car did still run on 3 cylinders after smashing several "fingers". Ask myself as it ran then, why doesnt it now when its only a fraction out?
Fuel pump is working fine.
Cheers
Phil
Cheers
Phil
Sounds like ur timings jumped
Manual, Rear Tints.
Manual, Rear Tints.
- lozz
Iwouid check the condition of the timing belt,
if thats ok iwouid Re:time it and go from there,
Did the aux belt actualy find its way into the cam belt, was there any bits of it in there ?
I'd take it back to whoever did the time and get them to retine it put a new belt on n check the tensioners. U still got a month or two guarantee on it for them to do it for free.
Manual, Rear Tints.
Manual, Rear Tints.
- lozz
Good idea that,
but, they will most probs say the problem was caused by the aux belt,
if iwas running a garage, iwouidnt touch it, obviously if the aux belt as Failed its not been Replaced,
iwouid ~Renew any Aux belts whilst replacing a cam belt, the Extra £15 can save £100s
Thanks for the help so far, still wont go!
Timing was well out, I'd picked up the wrong slot on the flywheel, read a brilliant post on here and that put me right!
Timing is now spot on but it still wont fire, lots of compression [injector seat is leaking a bit on No3, i think it has for a while], fuel pump under seat is whirring away, fuel is getting up to the injectors and Ive reset the BMI. Is the rev counter supposed to read whilst its cranking as mine doesnt, and I cant remember if it should or not.
Any help/ideas would be much appreciated, got to go to work on the bus!
Cheers
Phil
Cheers
Phil
- lozz
Rev counter shouidnt move whilst cranking,
Have you tried starting it up on sniff ?
Have the rocker cover off & check it's not broken the followers.
Well folks now I've had a chance I've took the rocker cover off and the problem is totally obvious! All 8 cam fingers are gone [lots of bits floating around]so thats my starting problem.
I have one extra problem in that one valve is missing its collet/top washer, and wonder if anyone has seen this before? Can the snapping of the fingers "dislodge" this, or will it have damaged the head or piston?
Head will have to come off, but I'm wondering if its worth doing!
Cheers
Phil
Cheers
Phil
- lozz
Sorry to hear that mate,
as of the Damage you wont know the full extent of it until the: c/ head as been Removed,
