Ventilation blower fan has packed up
Davva2004
Location: Stood beside my 406 with a sledgehammer, cursing everything French
Post by Davva2004 »
Hi guys,
My ventilation fan has stopped working... just wondered if it's more likely to be the switch or the fan itself before I pull the dashboard out? Does the fan have its own fuse, or does the circuit it's on cover multiple items? Everything else on the control panel works as it should, just turning the fan speed knob has no effect at all.
Thanks guys
Dave
[email protected]
Niz406 wrote::arrowu: Winner of the 2007 New Years Competition :cheesy:
Have a look under the glovebox. I had the same problem and found someone had simply kicked the connection out of the motor.
Blue406
406 Gimp
Post by Blue406 »
I do believe it has its own fuse. Check the hand book for what all the fuses do. Might be worth your while.
Davva2004
Post by Davva2004 »
Cheers guys! :mrgreen:
[email protected]
Davva2004
Post by Davva2004 »
Following all your suggestions, I planned to have a root around under the dash at the weekend.
This morning, half asleep, get in the car, turn the ventilation fan knob and.... it works.
French electrics confuse me. :evil: :cry: :x :frown:
[email protected]
Davva2004
Post by Davva2004 »
Now I'm not just confused, but almightily p!ssed off.
I have a sequential fault. HOW THE F*CK IS THIS POSSIBLE????
Turn ignition on, fan works. Turn ignition off, then on again, and it doesn't. Turn off then on again, and it works. Repeat as necessary.
Is there a relay controlled by the ignition circuit that sends power just to the fan motor? Because if there isn't, I'm REALLY stumped. Every other control on the heater panel works, all the buttons light up as they should, absolutely everything else in the whole car is working as it should, I just have this one annoying fault and because it's obviously not a mechanical problem or a permanent break in the power supply, I'm totally stumped.
[email protected]
Maybe there's a reset procedure you can try? Unfortunately, I don't know of any but there are certainly combinations to reset the ECU, leccy windows and such...
Davva, you have every right to be annoyed at your Peugeot Electrics, nothing seems to be simple does it?
It seems Peugeot and Citroen give us these brilliant innovations in car electronic features but they don't have the simple reliability and quality needed in a moving vehicle.
Seems the faults you get can be caused by something completely remote and you would have no idea why, I mean why should a crappy handbrake warning switch say 'Brake Fluid Level Low' and so on.
For what it's worth, I've had this on another car and it was the resistor pack attached to the Fan Body itself, if you have a fan switch that goes 1,2,3 & 4 etc then the resistor pack sorts out the fan speed, they normally blow and you lose one or two of the speeds though, not the whole lot, I would start with that and the switch itself.
(you may have detected I am going through the 'Peugeot Nightmare Electrics' with my car at the moment :| )
Davva2004
Post by Davva2004 »
I see my 406 has that famous french adaptive fault management system installed, must have missed that particular box when ordering it from Peugeot.
What I WAS doing is... turning the key to the pre-start position, if the fan isn't working I turn it back again and then try again, and without fail the fan would be working so start the engine and away I go with fresh air.
BUT... my 406 has figured out that I'm doing this, and to really raise my blood pressure to the point where the veins in my temples are standing out like lumpy purple hosepipes, it now lets the fan run in the pre-start position... lulling me into a false sense of security... and then cuts the fan off when I start the engine.
Which just about drives me abso-f*cking-lutely BATSH!T.
I've not seen the technical way of resetting the ECU, however I am fully prepared to thrash my car to within an inch of its garlic-ridden snail-eating beret-wearing stripy-jumper-on-a-creaky-bicycleish life with a selection of garden tools, up to and including a combine harvester to see if that will help in any way.
After I've done this, I'm declaring war on France and sending in raiding parties to free baguettes from captivity and stop their unpasteurised soft squishy cheeses from killing pensioners. I'm also forming the SLF (Snail Liberation Front) and will make a concerted effort to disrupt the supply chain to their horse farms as no-one in their right mind really wants a six foot horse drumstick on their table for dinner. Plans to introduce a specially mutated weevil that only eats garlic (and doesn't mind not getting snogged at the end of a friday night out) have been laid and I'm anxiously awaiting the first batch that are thankfully being cultivated downwind from me. Hopefully following all of the above, the average French worker will be too tired from starvation to make any more Peugeots and we can all go back to normality and buy Fords.
[email protected]
Blue406
406 Gimp
Post by Blue406 »
I know I shouldn't be laughing... but Davva.... that post hit my funny bone square one... I'm really in fits here!
Post of the Year!!
I take it your not too happy with the old Puggy at the moment :shock:
It is OK davva to be cross with your Peugeot, but in a strange sort of way they are kind of amusing at the same time........as if you are already prepared for such electrical drama's that you simply can't help but ridicule the car.
'Quirky' is a nice little term for french cars........Full of Character :cheesy:
People have documented for years that Peugeot's are great cars, mechanicaly very strong, comfortable, long lasting etc etc but watch those electrics!!!!!!..........seems that will allways bug Peugeot eh?
MaDc0w
Post by MaDc0w »
If you do pull the dash could you take a pic where that thing is????
I just wanna cut the cable SO IT STOPS CLICKING!%"&//§"§$ :cheesy:
Can't I get to it without taking half the dash apart? I don't see it behind the glove. :|
The electrics in the 406 are horrible. My left window and I play this game.. It opens fine, randomly it closes itself, I push the button again to go up and it goes down again. Then I keep trying to close it but it will always randomly open. But if the motor isn't running my window sleeps and waits for me to start the car again. The electrics watch you and wait for the worst time to annoy you... Like at a toll in the rain..
Oh and threatening to junk or scrap it, or kicking it doesn't seem to help either :D
Welton wrote:Couldn't help it........... at first it was the picture of the 2 tone grey 406........and then later the monitor just got sprayed
406OC Image Support
colinmazu
Post by colinmazu »
My W reg 406 2.0 HDi has just started doing this too. Sometimes the blower runs untill you start the engine, then it doesn't. I have noticed that if you bash the stearing wheel cowling on the underneath, it starts to work again.
I think mine must have a loose connection or summut there, haven't had a chance to have a look at it yet though.
Cheers
Col
MaDc0w wrote:The electrics in the 406 are horrible. My left window and I play this game.. It opens fine, randomly it closes itself, I push the button again to go up and it goes down again. Then I keep trying to close it but it will always randomly open. But if the motor isn't running my window sleeps and waits for me to start the car again. The electrics watch you and wait for the worst time to annoy you... Like at a toll in the rain..
Sounds like your window motor might have had it. When they hit a certain amount of resistance when closing (and this is the same for any semi-modern car) they'll back off in case the resistance was caused by a child's neck. Personally I'd prefer my windows to operate under a natural selection philosophy but hey... Anyhow, if your motor ain't generating enough torque to close the window it'll trigger whatever mechanism senses the resistance... Following on from this, your electrics generate less current when the engine's not running which might be why it doesn't work when the engine's off.
Or you might just need some WD40 on a pulley or something...
MaDc0w
Post by MaDc0w »
I thought that too....BUT... the right side window has NO child safety... tested with my arm (ouch). .. no way arround a scrappies visit soon. :) I also have an odd feeling my alternator is going. Short live French electrics. :)
406OC Image Support
