Cant get rear caliper pins out (ones that need hammering)
jason1987
Post by jason1987 »
ive been using a small hammer and screwdrivers to try and bang it out but they dont seem to budge.
also didnt get any new pins with the pads so i hope they go back in ok
jason1987
Re: Cant get rear caliper pins out (ones that need hammering
Post by jason1987 »
ill get a bigger hammer and some caliper punches tomorrow, hope it comes out ok and i havent ruined the ends of the pins
Hm I am about to embark on a similar journey. Have you read mjb's howto? Soak it in WD40 overnight, should help.
Been there, done that, here's the tee-shirt - viewtopic.php?f=27&t=13560&hilit=back+brakes
jason1987
Post by jason1987 »
just read the how to on Adjusting the handbrake on disc type drums, but it doesnt say whether you do all the procedures with the handbrake on or off, anyone know?
Off is always preferable.
jason1987
Post by jason1987 »
just hope these fiddly pins will come out if i get a punch
You are punching them out to in, yes? It always amazes me that garages put stuff like this back together without any form of lubrication, I suppose they save themselves a massive 20 seconds a side and a few microgrammes of copper grease :roll:
jason1987
Post by jason1987 »
im punching them from facing towards the car from the small ends
TRAVIS BICKLE
Post by TRAVIS BICKLE »
A proper good clean up with a wire brush, a good soak in WD40 and if they still wont move i usually work them loose with a good set of vice grips, once you get them to turn a little they will come out no probs 8)
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
jason1987
Post by jason1987 »
i need a punch though dont i
A pwoppa parallel pin punch would be useful, yes. I'm sure you can pick something up from Halfords, or even your local factor's.
What about just cutting through them? Would that work?
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Post by DiscoPol »
cutting is the easy option but i dont think he has any new ones :roll: and is hoping to reuse the old ones.
i think he needs to get a fresh set and just butcher the old ones off.
jason1987
Post by jason1987 »
dont most pads come with new ones? they were pagid ones aswell so not cheapo
