Koni suspension kits, what models will they fit?
v6saloon
Post by v6saloon »
Hi guys, i have a 2001 v6 saloon (210bhp) an am after a good suspension kit, i came across these but it says in the discription they are for a 2.0i 2.0td and 2.2td but i thought that they would fit any 406, can anybody shed any light on wether they will fit mine ok? thanks in advance :)
http://www.dcperformance.co.uk/uprated/ ... t/406.html
omega
Re: Koni suspension kits, what models will they fit?
Post by omega »
i would give then a call.
i "THINK" that the diffrence will be in the strengh of the springs/shocks.
i think the HDi and V6 springs are different you need to check 1st
The standard springs on the V6 are the same as the 2.1td. If that helps. Ok, perhaps not.
More useful: Koni's own katalogue seems to say they fit all :? and use the original front struts :? :? :? I think you need to ask.
