Speaker wire colours. 406 Estate
Knowledge Base Articles
Locked
Mastiff
Post by Mastiff »
For all the want to add aftermarket speakers to your Pug then here is the wire colour code!
Front Left...... Purple is + and Grey is -
Front Right (Drivers side) is exactly the same as above.
Rear left..... Light Brown is + and Red is -
Rear Right..... Yellow is + and White is -
This was taken from a 2001 406 LX Estate. I'm sure other Estates will be the same, maybe saloon versions aswell.
Re: Speaker wire colours. 406 Estate
Excellent. Just to double-check - on aftermarket speakers, the fat one is +ve & the thin one is -ve?
I think that's right, although it doesn't matter if they're all the same. Or use your 9 volt battery again, apparently if you put the plusses together and the minusses together the speaker will pop outwards.
Just about to copy this to the KB.
Locked
