Someone please make me like my 406 again...
Bailes1992
Post by Bailes1992 »
After spending around £2000 repairing bits and bobs. The fuel pumps now weeping diesel, my rear windscreen wipers stopped working and now my cooling fans won't go off :cry:
I've really had enough, writing the advert now for pistonheads to try get rid of the bloody thing before I put a hammer through the windscreen of it.
I took it for a nice thrash along some coast roads and realised what a good car it actually is, then got out to the sound of cooling fans which have been on since 10am after a run to Cardiff :( Just pulled the fuse on them... *sigh*
Anyone got any advice to whats up with the cooling fans? I have a D9 HDi here I can pinch a few parts from to try on mine to see what the problem is if thats any use?
Ta, Bailes.
Re: Someone please make me like my 406 again...
Cooling fans staying on? Sounds like the coolant temperature sensor to me. I'll have a dig through autodata & see if I can track it down unless someone with servicebox access beats me.
Keep the faith Sam, by the time you've fixed these niggles you'll have a cracking car. Better the devil you know and all that!
Bailes1992
I don't think it is, cause when I pull the plug on the sensor the fans go on full speed, when it's plugged in they stay on low speed.
I don't think I can fix all the niggles, the more I sort the more than turn up :(
Has your car got aircon?
Bailes1992
No it hasent... if it did... it wouldn't work anyway :P
:lol: Was just a thought :wink:
Bailes1992
darrenwall
Post by darrenwall »
Bailes1992 wrote:I don't think it is, cause when I pull the plug on the sensor the fans go on full speed, when it's plugged in they stay on low speed.
i had a 405 1.9 td that did that , i was told its a fail safe system so if the switch goes or the wire breaks the fans come on so the engine wont cook itself , dont know if its true but when i replaced the fan switch on the thermostat housing the fans worked as normal then
just dip me in chocolate and throw me to the lesbians
Bailes1992
Thing is this happened before, and after a drive with the fuse out it was fine again? So think it might be a sticky relay but I don't wanna change it if it's not the cause :(
darrenwall
id try the fan switch first if i was you cos they are cheap enough and as far as i know they are universal between all older pugs , it was just a different colour to determin the temp it would turn the fan on
Bailes1992
Wheres that located too?
darrenwall
on the 405 it was on top of the thermostat housing but on my 406 2.1 td it was on the near side of the rad , hope that helps
Bailes1992
Ohh the actuall brown sensor on the thermostat?
Thanks :D
I'l get it changed tommorow hopefully. Not sure which one of these it is though?
http://www.eurocarparts.com/ecp/c/Peuge ... nd-Sensors
Could also be a stuck relay...
Bailes1992
Wheres the relay located? Whats the Colour and how much are they? If there only a few £££ I'l get bopth of them :)
