Possible binding brake(s)
Re: Possible binding brake(s)
This one sounds like a process of elimination to find the fault.
Firstly, I would run it up to normal speed then take it out of gear and freewheel, A wheel bearing noise would be heard freewheeling, sometimes it gets worse with movement of steering wheel, sometimes the noise goes off.The noise would be a humming or a whirring.
A transmission noise would go away if you took it out of gear and freewheeled.A driveshaft would clunk on turning the steering in the direction of the problem.
Do you feel anything through the steering? If so, I would check the tyres for being out of shape or a bulge in the tread or sidewall.I've had many wheel bearing noises traced to tyres, the steering would "wobble" in your hand and make a thudding sound.Strangely enough, my son's Astra had a loud noise on his o/s front, turned out to be a huge screw stuck in the tread, made a horrible noise!
A rear tyre or bearing fault (rear bearings are a common fault) would give a vibration humming throughout the car, like it was shaking the wheel, ie, an "S" shaped tyre.
I guess I would jack up all the wheels and make sure no brakes are sticking on, then spin up each one in turn, starting with the main suspect.If you have axle stands, jack up n/s front and axle stand it, then start the car and put it in gear, let out the clutch and change up through the gears, then take it out of gear, you will soon eliminate or confirm wheel bearing, of course, if the brake is stuck on, don't try to run it on the axle stand.Take care with safety.
I hope I you made sense of my post and it was useful.
All the best.
All the best.
Sometimes need to 'wiggle' the rotary switch, from folded to L or R positon & back again on mine.mjb wrote:That's what I thought... but nothing happens. No sound of motors, nothing.
Is there something you have to do to enable the system?
*embarassed to add* needs ignition sw. on pos. 1 or more
- mjb
First thing I did after I got it out of first gear! I may not be too savvy under the bonnet, but if the clutch or gearstick "cured" the sound I wouldn't have blamed the brakes to start withjasper5 wrote:Firstly, I would run it up to normal speed then take it out of gear and freewheel, A wheel bearing noise would be heard freewheeling, sometimes it gets worse with movement of steering wheel, sometimes the noise goes off.The noise would be a humming or a whirring.
The sound is a grinding when going at walking pace turning into a constant droning hum at speed, and definitely coming from the nearside
I'd have definitely noticed that (it's REALLY loud inside - louder than the roar of the V6 at speed), although isn't part of the gearbox being driven by the diff when freewheeling?A transmission noise would go away if you took it out of gear and freewheeled.
NopeDo you feel anything through the steering?
Funnily enough, I did just this tonight. However I took my trolley jack but forgot the bloody handle so I only attacked the n/s front wheel.I guess I would jack up all the wheels and make sure no brakes are sticking on, then spin up each one in turn, starting with the main suspect.
It turned freely, but there was a very quiet irregular grinding noise and much more worryingly a rattle. It sounded like something falling every 180 degrees I turned the wheel. It was never *exactly* 180 degrees, but very close. Would this indicate I need a new driveshaft because the CV joint is shot? Or maybe a ball bearing rattling about (do wheel bearings use ball bearings or are they liquid like a computer hard drive?)? I can't think of anything else that could be aligned to the wheel position, but I freely admit I know crap about this stuff...
I wouldn't fancy tackling this one in the streetHaynes 3982 wrote:3 Front hub bearings - 5 spanners!
renewal
Note: The bearing is a sealed, pre-adjusted and prelubricated, double-row roller type...
blah blah blah
Note: A press will be required to dismantly and rebuild the assembly; if such a tool is not available, a large bench vice and spacers (such as large sockets) will serve as an adequate substitute. Blah blah blah
1. Remove the swivel hub assembly as described in section 2.
I'm still not sure what it is though - bearing or UJ. UJs usually make a racket on full lock (clop clop clop) while the noise from bearings changes as you sling the car about. I suppose this more applies to "wearing out", completely destroyed might be different.
- mjb
Aye, I'm already thinking it's a garage job.steve_earwig wrote:I wouldn't fancy tackling this one in the street![]()
Driveshaft (CV joint) would knock on full lock, but if badly worn, would also knock or rattle driving straight.
I would have the wheels on the ground and grip the driveshft, twisting it back and forth to try and hear any rattle or feel any slackness....compare it with the other side.
Again, jack it up and drive the wheel through the gears and listen for the noise.
I've done wheel bearings in the street, taking off the whole hub and bashing out the old bearing and gently knocking in the new one, you have to soak the whole bearing assembly in WD40 or penetrating oil, there will be a circlip of some sort to remove.
I have a socket that fits the old Ford Granada rear hub nuts, this is usually perfect for knocking out bearings.
Can't think of anything else.
- MartinV6
- 1.8 8v
OK, I'm worried about my hearing now - neither my wife nor I noticed any odd noises. Saying that, I did not notice that interior fan you mentioned either. Perhaps commuting 100 miles each day on the bike has had more effect than I thought.mjb wrote:I'd have definitely noticed that (it's REALLY loud inside - louder than the roar of the V6 at speed)
I hope you get it sorted cheaply, and easily whatever it is.
Martin.
98 V6 man 4dr - 103k miles
plus some bikes and an 80s 335i cabrio.
- mjb
It's easy to assume the noise is normal - it's quite similar to the engine sound of modern Ford dieselsMartinV6 wrote:OK, I'm worried about my hearing now - neither my wife nor I noticed any odd noises.
I've got another problem though. The clutch is slipping
However, the clutch feels very spongy and bites incredibly high without any feedback other than the strong vibrations (which start a fair bit before the bite), and the brakes aren't as sharp as I'd expect, so I've got me a bottle of DOT4 and am going to try a brake fluid change with the new engine mount before I jump to conclusions. Now how on earth do you bleed the clutch on these things
- 2.2 16v
This is begining to sound like a DMF problem, what engine is it.
406 HDI Exec Estate (2 off) & 307CC HDI Cabriolet
- mjb
3.0V6 (ES9J4) - solid flywheel
I'm going to have the hydraulics bled and top mount changed tomorrow (maybe tonight on the hydraulics, if I can bleed the rears without getting the jack out), so we'll see what that does for the symptoms... I'm hoping the slipping clutch could just be that the fluid between the cylinders has become aerated through the rubber, taking up more volume and thus pushing the clutch in on its own. I did mention it bites exceptionally high...
The fluid's a bit manky, so it's possible, non?
I don't know if it's possible or not but it won't help.
If it's the same as the cars covered in the D9 Haynes there should be a nipple on the slave cylinder, you'll have to shift the air filter etc. to get to it. Haynes says you can't use an eezibleed (some bollox about the fluid foaming), you have to do it the old-fashioned way with an assistant pressing the pedal and a tube into a jar from the slave.mjb wrote:Now how on earth do you bleed the clutch on these thingsGuess I'm off to Halfrauds tonight for a D9 Haynes
- mjb
Yeah not long ago I realised I'd got a scan of the D9 Haynes around, so had a peek. I think the system it was referring to was a pressurised bleeding tool. A one-way valve should be fine - it's essentially the same as the 2-man method, except using a valve instead of the other guy opening and closing the bleed nipple...steve_earwig wrote:If it's the same as the cars covered in the D9 Haynes there should be a nipple on the slave cylinder, you'll have to shift the air filter etc. to get to it. Haynes says you can't use an eezibleed (some bollox about the fluid foaming), you have to do it the old-fashioned way with an assistant pressing the pedal and a tube into a jar from the slave.mjb wrote:Now how on earth do you bleed the clutch on these thingsGuess I'm off to Halfrauds tonight for a D9 Haynes
On a (very) quick inspection earlier I couldn't see the bleed nipple on the rear calipers. Erk! Could be co-codamol time again :/ How much are cheap cordless impact drivers suitable for removing wheel nuts nowadays? Can I get one from Tescos?
- DaiRees
I got a 12V (fag lighter) one from Aldi or Lidl for about £15. It's done all sorts of 15yr rusted, shyte covered bolts on my Zook so I'm quite happy with it.mjb wrote:On a (very) quick inspection earlier I couldn't see the bleed nipple on the rear calipers. Erk! Could be co-codamol time again :/ How much are cheap cordless impact drivers suitable for removing wheel nuts nowadays? Can I get one from Tescos?
- mjb
Here's a thought - would a shot CV joint not make a lot more noise and some vibration on turning, and change in intensity under hard acceleration/braking?
I'm also wondering if i'm wrong about the front n/s too, as the grinding really does fill the inside of the car (and my head) making it very difficult to pin the sound down... How loud would a shot bearing be with the wheel in the air?
The only way to get to the bottom of this is going to be to get to the work car park on Saturday and break my back getting each of the wheels in the air ain't it :/
With the wheels off the ground, it would be fairly obvious if you had a faulty wheel bearing or a drivesahaft/cv joint problem, the wheel bearing will hum loudly, the driveshaft/cv joint will rattle loudly.It will be obvious if you compare the suspect wheel to any other.
