406 V6 - Starting problem / missfire
- Newbie
Hi there from a newbie to this forum, who is asking for help on an annoying problem!
I have recently bought my 98/R 3.0 V6 Manual (197 bhp) with body damage with the intention of repairing it.
It starts ok from cold. However, when the car's been driven it gets increasingly reluctant to start.
The car "runs" well and doesm't show up as running hot or anything ion the IP.
However, if you start the car and let it idle, then plant your foot on the throttle, it momentarily dips, before picking up - and almost fractionally "misses" before revving - you notice it pulling out froma junction or overtaking. I don't know if the 2 probs are related (possible that they are).
I took it out the other day to get a paper (first time for about a month). It started up fine and went ok. However when I pulled up some 2 mins away from my home (car still cold) it hesitated then stalled. It then took ages on the key to start (about 30 seconds) - When it eventually did start, there was a LOT of white emmissions.
Any advice appreciated?
Thanks,
Gallen.
Thanks,
Gallen.
- mjb
Re: 406 V6 - Starting problem / missfire
Dodgy throttle pot? Dunno how much they cost to replace, but they're a piece of cake to get at on the v6
One way of testing is to get an aerosol can of freezer stuff from maplins. You spray it on something to make it COLD - staff there should know what it is from that description ;) Warm up the engine so it exhibits these symptoms and then start spraying stuff until the problem goes away and you know what to fix/replace
- Site Admin & Mad Biker!
Either that or it could be a faulty oxygen sensor
I would be thinking along the lines of spark plug coil pack etc.
Without being rude it might help to ask over on the coupe forum as they have more V6's than we do here and I can't recall anyone with a running problem on this engine
- TooT
Sorry i cant help. Mine was 100% reliable for 2.5 yearsWelton wrote: I can't recall anyone with a running problem on this engine
- jameslxdt
mileage?
when where the plugs last changed?
sounds like either a faulty coolant temp sensor, oxygen sensor
i would go with plugs first, might be rear bank head gasket gone
- mjb
ouchjameslxdt wrote:might be rear bank head gasket gone
- jameslxdt
very common with high mileage non-VVT V6 unfortunatley
- mjb
you're just saying that to scare me... aren't you?jameslxdt wrote:very common with high mileage non-VVT V6 unfortunatley
what's "high mileage" for an es9j4?
- jameslxdt
depends how its maintained, if its not been looked after then arround 150k well maintained 200k
- mjb
phew!
what if it's been well maintained, but thrashed? *COUGH* ;)
but not a problem on the vvt (210bhp)????
sounds like another reason me to search for the 210!
1997 Honda Prelude 2.2 VTi
- jameslxdt
doesnt affect the VVT V6 as the engine was re-designed, the problem with the non-vvt was alloy head, steel gasket, iron block
alloy and steel arent a good mix
- mjb
ah but VVT means D9 which means the electrical subsystem is likely to break horribly long before the engine starts thinking about retiring ;)
- TooT
Not true, mine was a D9 without VVTmjb wrote:ah but VVT means D9
