Haynes manual
Haynes manual
Greetings from a newbie
Have to remove the front bumper by the looks of things just to replace the front fog light !! My question is, the Haynes manual available from halfrauds only covers up to 2002. As mine is an 03 model does anyone know if this is also covered ?
Re: Haynes manual
yes mate ithink yours will be coverd in the haynes manual,kasper wrote:Greetings from a newbie
you couid always save your self a few quid by posting a thread people on here will be able to give you info on how to remove the bumper.
ithink you might be able to get away with not having to remove the bumper to change fog light
Re: Haynes manual
Thanks for the response, will have to get myself one cause it definately looks to me as the only way to reach the top torx screw is by removing the washer bottle which for some reason is fixed from the front !! hence the bumper removal
Re: Haynes manual
you do not need to remove the bumper to change a fog light.
i know cos i fitted 2 new fogs to my car only weeks ago.
get the car jacked up in the air as high as your jack will take it. remove the bottom wheel arch plastic cover.
access is easy under the car.
oh ang on mine is a D8 but im sure it will be similar for a D9
Re: Haynes manual
just take engine undertray off
Hynes manuals are floating about the net Download one
Re: Haynes manual
or do as i did and buy one of eblag cost me 3 quid with the postage
jolly green giant 1.8 16v LX estate
- 1.6 8v
Re: Haynes manual
Aye I'm the same, been trying to find a manual cause I like reading them lol.. Every 406 one I have seen does not support 2.0 hdi Diesel engines which mine is I'm at a loss
Re: Haynes manual
You must have brought the wrong one then cause Haynes Manual no 3982 covers the whole lotBawkicker406 wrote: ↑Tue Aug 21, 2018 4:06 pm Aye I'm the same, been trying to find a manual cause I like reading them lol.. Every 406 one I have seen does not support 2.0 hdi Diesel engines which mine is I'm at a loss
Except the V6, 2.0 petrol turbo, 2.0 hpi & the 2.2 petrol
It does cover the petrol 1.8 & 2.0 also the 2.0 & 2.2 hdi's
Re: Haynes manual
I can share a PDF version with you if you like?
Its not the same I know, but its worked for me recently.
- 1.6 8v
Re: Haynes manual
wow ok cool. I must be looking in the wrong place lol
