and today i have mostly been...
Re: and today i have mostly been...
Cheers guys, he trouble was it was hard to see what was going on with her because she just ran away all the time, every time i found her she moved somewhere else. When she stopped doing that though, it was obvious she'd given up.
Cats all have their own personalties and idiosyncrasies, sometimes Billie was such an affectionate cat, she'd just jump on a chair and want big lovvin' but the rest of the time you could feck right off.
Bailes1992 wrote: Tue Jun 26, 2018 8:35 am as soon as you touch the throttle it floods
Floods! You sure? I know a lot of these tiny Walbro etc. carbs have some sort of control valve in the bottom, I'd imagine if this is stuck or broken then it could flood it. Pull the base off and have a squint? Also, dodgy diagrams can give all sorts of issues, if it's sat with fuel in it for a few years they could be borked.
Modern fuel is crap, too much ethanol etc. If left it'll just sit in the fuel system eating all the seals and turning into incombustible gloop. If it's not going to be used for a month or more we're advised (by Walbro) to drain the tank and run 'em dry. Seems a bit excessive to me so mine only get run dry at the end of the year.
trufflehunt wrote: Tue Jun 26, 2018 10:33 am but main jet blocked.
Then it'd run weak Shirley? Sam says floods :?
Bailes1992
Post by Bailes1992 »
This thing is flossing. Sparkplug comes out soaking.
I spent several hours trying to get a lawnmower to run right, only to discover the petrol can was mostly full of water cos my son left the cap off in the rain......
:roll:
My McCulloch 2-stroke strimmer cuts out with the slightest throttle but only after idling for a long time; literally squeeze the throttle and it stops. The internet told me to try a decent 2-stroke oil so I bought some Oregon stuff, not tried a new mix yet though :roll: running on Super Unleaded seems preferable too.
Doggy wrote: Tue Jun 26, 2018 12:35 pm I spent several hours trying to get a lawnmower to run right, only to discover the petrol can was mostly full of water cos my son left the cap off in the rain......
Didn't we have someone with a similar problem with his diesel 406 a few years back? Found a drum of "diesel" on a building site with unknown origins...
Welly wrote: Tue Jun 26, 2018 12:39 pmMcCulloch
I once borrowed a McCulloch strimmer off a mte, do you think I could get it started? SO I asked the Oracle (me dad) for advice and he suggested borrowing a strimmer off another mate that didn't own a McCulloch... That actually sounds like one of the behaviours I got from my Husqvarna the first couple of years I had it, I even tried the later carb for it, to no effect. Then my dad told me to feed it 25:1 instead of 50:1 - tranformed :shock: I eventually read in the handbook (like you've all read yours cover to cover :roll: ) that it's 50:1 unless your not using Husqvarna's own speshul 2-stoke oil, in which case it's 40:1. These days everything gets 25:1, I can't be having with 2 bottles of premix hanging about.
Incidently, I was once told (probably by The Oracle) not to cheap out on 2-stoke oil. It's a lot like putting cheap 'n' crappy engine oil in your motor.
Finally, a while back I bought a litre of Briggs & Stratton 2-stoke oil, it's in a black bottle so I didn't know until I opened it that it doesn't have any red dye in it. What's the problem with that? Every time I go to tip some fuel in I look at the bottle and ask myself "did I mix this or is it neat?" I may give it away...
My Mcbolloch says 40:1 on it's fuel bottle/tank but you reckon a stronger mix is better, don't you get smoke though?
Not a lot. Tbh when I'm a-fiddling with the mixture I like to see a tiny bit of smoke, I don't trust these things or myself to get it 100% right and I'd rather be on the rich end of the scale and use a little too much fuel than make a hole in a piston.
Mix up a little (maybe half a litre with, umm, 200ml per 5 litres would be 20ml for 0.5l) and see what she runs like.
If in doubt http://ebusinessconsultant.co.uk/2-stro ... alculator/ (lots of this sort of thing about, doesn't hurt to double check either :mrgreen: )
I have a proper 1ltr mixing bottle with a range of 'mixes' marked on it so it's quite easy to adjust the recipe.
oo-OO-ooh! Get you with your fancy one litre mixing bottle with a range of mixes marked on it :P
I've just got a 5l water bottle from the gas station :frown: Before you ask, I've had it a few years and it still didn't dissolve.
NO need to smug Welton. Might I gently point out that metric measurements will be phased out from 11:00 29/03/2019?
Anyone failing to transition to imperial units thereafter is liable to summary removal from these shores.
steve_earwig wrote: Wed Jun 27, 2018 10:55 am oo-OO-ooh! Get you with your fancy one litre mixing bottle with a range of mixes marked on it :P
This is it, from B&Q (other competitively priced store are available):
I'll get you one for Christmas if you want :lol:
Doggy wrote: Wed Jun 27, 2018 12:45 pm NO need to smug Welton. Might I gently point out that metric measurements will be phased out from 11:00 29/03/2019?
Mate if you're running 11:00 mix you'll wear the rings.
Welly wrote: Wed Jun 27, 2018 3:46 pm I'll get you one for Christmas if you want :lol:
Do they come in 5 litres? I think the mix on the Homelite works out at 16:1, do they cover that? (It pre-dates 2.stroke oil but hey, runs fine on 25:1)
Meanwhile..
He is laughing, not in agony...
The artist at work
Note safety gear - steel toecaps and his wife's old spectacles.
Moving on
Almost there
Done!
Next: the roof. Probably.
