Yet another problem has been added to the pile, the steering wheel volume stalk has completely died. I'm not sure if it's got a fuse or if it's connected to the radio but a little annoying when trying to change volume whilst driving. If anybody could help me out here. A new stalk is not really an option. Thanks
It's a 2002 so not the new style.
Sent from my iPhone using Tapatalk
Steering wheel volume stalk problem
- peugeot30v6
2002 Peugeot 406 V6 Auto Executive [95100miles]
2003 Peugeot 406 HDI 110 Executive Manual [157000miles]
2002 Volvo S60 2.0t Auto [287000miles]
Re: Steering wheel volume stalk problem
2002 would be "the new style", your car must have sat around for a bit.
Do the old stalks only do volume or does the other stuff work?
Ah crap, I thought I'd better check in case anyone suggested it and D8 stalks are different.
- peugeot30v6
it's completely dead, no movement on volume mode or change.steve_earwig wrote:2002 would be "the new style", your car must have sat around for a bit.
Does the change (mode?) work or is that borked too? Could it just need "reseating" (disconnecting and plugging in again)?
- peugeot30v6
Nothing is working. I have tried to disconnect and reconnect the battery terminal but that hasn't changed anything, how would I go about resetting it, would I have to take the stalk off?
On the wiring diagram it looks like it's got a socket on the stalk and the other end is plugged into the MFD (why?)
- peugeot30v6
Thanks for the help! Took off the steering wheel column casing and found a wire had been rubbing up on the steering rack itself. Soldered back on and it works.steve_earwig wrote:On the wiring diagram it looks like it's got a socket on the stalk and the other end is plugged into the MFD (why?)
